Tim Tang avatar image
Tim Tang asked
AuthToken verification failed
When I run my app , it always reports the following error, I have fully followed the documentation instructions for integration.
iap
Tim Tang answered
The Debug info:
qingwanplay.topdesigner.amazon2 D CommandServiceClient: Blocking for result from service
2023-07-21 17:34:41.487 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D CommandServiceClient: Received result from service
2023-07-21 17:34:41.488 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D AbstractCommandTask: Received result from CommandService: CommandResult: [CallingUid: 10389, SuccessResult: null, FailureResult: com.amazon.d.a.h$a$a@38ce6a4, DecisionResult: null, ExceptionResult: null]
2023-07-21 17:34:41.488 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D CommandResultVerifier: Verifying auth token: com.qingwanplay.topdesigner.amazon2
2023-07-21 17:34:41.488 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D DataAuthenticationKeyLoaderV3: Loading data authentication key...
2023-07-21 17:34:41.488 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D DataAuthenticationKeyLoaderV3: Checking KiwiDataStore for key...
2023-07-21 17:34:41.488 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D ExpirableValueDataStore: Fetching value: DATA_AUTHENTICATION_KEY
2023-07-21 17:34:41.488 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D DataAuthenticationKeyLoaderV3: Key was cached: true
2023-07-21 17:34:41.489 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D SignatureVerifier: Verifying signature of data: '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', signature: 'com.qingwanplay.topdesigner.amazon2', with key: 'OpenSSLRSAPublicKey{modulus=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,publicExponent=10001}
2023-07-21 17:34:41.489 12983-13022 Kiwi com.qingwanplay.topdesigner.amazon2 D AbstractCommandTask: Exception occurred while processing task: com.amazon.a.a.n.a.a.a: AUTH_TOKEN_VERIFICATION_FAILURE: null: null
at com.amazon.a.a.n.a.b.a(AuthenticationTokenVerifier.java:94)
at com.amazon.a.a.n.a.a.a(AbstractCommandTask.java:204)
at com.amazon.a.a.n.a.a.a(AbstractCommandTask.java:131)
at com.amazon.a.a.n.b.b$1.run(SimpleTaskPipeline.java:179)
at android.os.Handler.handleCallback(Handler.java:938)
at android.os.Handler.dispatchMessage(Handler.java:99)
at android.os.Looper.loopOnce(Looper.java:211)
at android.os.Looper.loop(Looper.java:300)
at android.os.HandlerThread.run(HandlerThread.java:67)
