Dominic Bilke avatar image
Dominic Bilke asked
Login and Request script doesn't work
my Login and Request Script doesn't work with JavaScript.
Can anyone help?
The Login works, and displays the Login window of Amazon. I can get the access code and profile information. But when I want to get the users playlists an error 401 occurs. The users playlists cannot be fetched. The ajax request is the problem...
Can anyone correct my script?
Thanks.
<script type=\"text/javascript\">
    window.onAmazonLoginReady = function() {
      amazon.Login.setClientId('amzn1.application-oa2-client.22ac50...');
    (function(d) {
      var a = d.createElement('script'); a.type = 'text/javascript';
      a.async = true; a.id = 'amazon-login-sdk';
      a.src = 'https://assets.loginwithamazon.com/sdk/na/login1.js';
      d.getElementById('amazon-root').appendChild(a);
    })(document);
    var authCode = '';
    function doLogin() {
        options = {};
        options.scope = 'profile';
        options.pkce = true;
        window.amazon.Login.authorize(options, function(response) {
            if ( response.error ) {
                alert('oauth error ' + response.error);
            return;
            window.amazon.Login.retrieveToken(response.code, function(response) {
                return;
                authCode = response.access_token;
                window.amazon.Login.retrieveProfile(response.access_token, function(response) {
                    //alert('Hello, ' + response.profile.Name);
                    //alert('Your e-mail address is ' + response.profile.PrimaryEmail);
                    //alert('Your unique ID is ' + response.profile.CustomerId);
                    if ( window.console && window.console.log )
                       window.console.log(response);
$.ajax({
        url: 'https://api.music.amazon.dev/v1/users/'+response.profile.CustomerId+'/playlists?limit=50',
        beforeSend: function(xhr) {
             xhr.setRequestHeader('Authorization', 'Bearer '+authCode)
             xhr.setRequestHeader('x-api-key', 'amzn1.application-oa2-client.22ac...')
        }, success: function(data){
                        data = JSON.parse(data);
                        for (let playlist in data.user.playlists.edges) {
                              let newOption = new Option(playlist.name,playlist.url);
                              let select = document.getElementbyId('amazon_playlist_id');
                              select.add(newOption);
   setTimeout(window.doLogin, 3000);
</script>
login with amazonrequestjavascript
