I want users of my Next.js TypeScript app to grant it permission to manage their Alexa Lists.
I figured this would be possible with OAuth2.
I figured I'd need to create a button in my website that takes the user to an Amazon URL that allows the user to grant my website permission to manage their Alexa lists (and then generates a code that it includes in a GET request that happens as a redirect to a "callback" URL that I registered as the redirect_uri when setting up OAuth2 in Amazon).
This is generally how OAuth2 works, in my experience.
I figured the button would be a link to a URL defined like:
const url = `${oauth2BaseUrl}?client_id=${encodeURIComponent(clientId)}&redirect_uri=${encodeURIComponent(redirectUrl)}&response_type=code&scope=${scope}`;
But I've found Amazon's docs unhelpful.
I see permissions / scopes mentioned here called alexa::household:lists:read alexa::household:lists:write.
I've set up my API endpoint (which I'll specify at redirectUrl) to exchange the Amazon authorization code for an Amazon access token following the code examples shown there.
I've set oauth2BaseUrl to be 'https://www.amazon.com/ap/oa' (found at https://developer.amazon.com/docs/login-with-amazon/authorization-code-grant.html).
For client ID, I'm using the one for my Alexa skill that I created. Is that correct?
I'm using Next-auth, but I'd be curious if there are any other libraries that could make any of this easier. Is there some way to use an Amazon SDK?
Here are permissions I've added in my Skill:
I always get:
400 Bad Request
An unknown scope was requested
But if I just use scopes these different scopes instead, I see it behave how I'd expect (but I lack List permissions): alexa::skills:account_linking postal_code profile:user_id.
P.S. I also started setting up Login With Amazon, but I don't understand why that would be necessary. I'm not looking to offer a federated login feature.
