shashchamp avatar image
shashchamp asked
can we change rootWhisperSyncFolder location
Hi Inside GameCircle() constructor I was trying to sync a different folder other than "/data/data/{0}", _plugin.Get ( "packageName" ) +shared_prefs I gave rootWhisperSyncFolder= "/mnt/sdcard/Android/data/com.example.sample/files/" But it was always trying to sync the previous folder only "/data/data/com.example.sample/shared_prefs". Didn't thrown any error though. Is there something I am missing or we just cant change the path.
Anshul@Amazon avatar image
Anshul@Amazon answered
Thank you for your post. We are forwarded your query to the concerned team and will get back to you once we have an update.
mikenelman avatar image
mikenelman answered
Hi shashchamp , I think the public static string rootWhisperSyncFolder in the GameCicle.cs script is only there for reference. So you can use it to know the whispersync's synchronisation folder, but not to set a new path. Whispersync probably uses it's how private/unacessible variable to synchronise. Remember that GameCircle is a external program. Even more, I am not sure that "/data/data/com.example.sample/shared_prefs" is synchronized. At least the one from my application was not. Only files in the "/data/data/com.example.sample/" was. I hope it will help :)
Hi shashchamp, We do not currently support Whispersync for data stored on sdcard. Hope this info helps.
