Luca Martinucci avatar image
Luca Martinucci asked
How to retrieve the AWS region where the Lambda function is running?
An Alexa skill I have developed calls a nodejs Lambda function that runs the same, identical code in different regions.
In order to customize its behavior according to the region, I have added an environment variable that "tells" the function which is its region.
I would like to retrieve this piece of information programmatically at runtime, in order to avoid using the environment variable and make the function totally region-independent.
Is it possible?
Thanks in advance.
lambda
Andy Whitworth avatar image
Andy Whitworth answered
The region is already available in AWS supplied environment variables, you don't need to add you own.
https://docs.aws.amazon.com/lambda/latest/dg/configuration-envvars.html#configuration-envvars-runtime
To access in node:
const region = process.env.AWS_REGION ||  process.env.AWS_DEFAULT_REGION
Not a python dev so don't have that code but check the AWS_REGION var first, it present then use that. If not present then use AWS_DEFAULT_REGION.
Luca Martinucci avatar image Luca Martinucci commented ·
I have tried the AWS supplied environment variables: they work fine.
Thanks a lot.
