Cecil avatar image
Cecil asked
Cannot delete Reference-Based Catalog
I created an initial Reference-Based Catalog with two versions. I then created a second catalog and a version. I edited the skill json to reflect the second catalog. It successfully saved and built, and appears to be working fine.
I want to remove the first catalog, but it tells me the catalog version is in use. I've tried removing each version and the catalog, but I continue to get the in use messages. What do I need to do to remove these or at least determine why it thinks the catalog/versions are in use?
Commands tried:
ask smapi delete-interaction-model-catalog-version --catalog-id CATALOG_ID_HERE --vers VER_NUM_HERE
ask smapi delete-interaction-model-catalog --catalog-id CATALOG_ID_HERE
reference-based-catalog-management
