Patrick Wogan avatar image
Patrick Wogan asked
My embedded audio using Alexa APL is no longer working.
I have an Alexa audio and visual response that is returned on the first launch of an Alexa App. I use a transformer to embed the APLA document. Up until recently this was working.
This is the APL document:
    "type": "APL",
    "version": "2022.1",
    "license": "Copyright 2022 Amazon.com, Inc. or its affiliates. All Rights Reserved.\nSPDX-License-Identifier: LicenseRef-.amazon.com.-AmznSL-1.0\nLicensed under the Amazon Software License  http://aws.amazon.com/asl/",
    "theme": "dark",
    "import": [
            "name": "alexa-layouts",
            "version": "1.5.0"
    "onMount": [
            "type": "SpeakItem",
            "componentId": "initialAPLAcomponent"
    "resources": [
            "description": "Default resource definitions for Video template",
            "dimensions": {
                "videoHeight": "55%",
                "videoPaddingTop": "80dp",
                "videoWidth": "70vw",
                "videoControlPaddingBottom": "0dp",
                "videoSliderPaddingBottom": "80dp"
            "when": "${@viewportProfile == @hubLandscapeLarge}",
            "dimensions": {
                "videoHeight": "60%",
                "videoPaddingTop": "110dp",
                "videoControlPaddingBottom": "10dp",
                "videoSliderPaddingBottom": "90dp"
            "when": "${@viewportProfile == @hubLandscapeSmall || @viewportProfile == @hubRoundSmall}",
            "dimensions": {
                "videoHeight": "50%",
                "videoPaddingTop": "70dp",
                "videoControlPaddingBottom": "15dp"
    "commands": {
        "ToggleVideoOverlay": {
            "parameters": [
                "componentId",
                "show"
            "commands": [
                    "type": "Sequential",
                    "commands": [
                            "when": "${show}",
                            "type": "SetValue",
                            "componentId": "${componentId}",
                            "property": "display",
                            "value": "normal"
                            "type": "AnimateItem",
                            "easing": "ease-in-out",
                            "duration": 1000,
                            "value": [
                                    "property": "opacity",
                                    "from": "${show ? 0 : 0.5}",
                                    "to": "${show ? 0.5 : 0}"
                            "when": "${!show}",
                            "type": "SetValue",
                            "value": "none"
        "ToggleVideoControls": {
            "parameters": [
                "componentId",
                "direction",
                "show"
            "commands": [
                    "commands": [
                            "duration": 1000,
                            "value": [
                                    "from": "${show ? 0 : 1}",
                                    "to": "${show ? 1 : 0}"
                                    "property": "transform",
                                    "from": [
                                            "translateY": "${!show ? 0 : (direction == 'down' ? -50 : 50)}"
                                    "to": [
                                            "translateY": "${show ? 0 : (direction == 'down' ? 50 : -50)}"
                            "type": "SetValue",
                            "property": "videoControlsDisplay",
                            "value": "${show ? true : false}"
    "layouts": {
        "VideoPlayer": {
            "parameters": [
                    "name": "backgroundImageSource",
                    "description": "URL for the background image source in fullscreen.",
                    "type": "string"
                    "name": "displayFullscreen",
                    "description": "Select to display video in fullscreen. Video controls will be displayed on tap.",
                    "type": "boolean",
                    "default": false
                    "name": "headerTitle",
                    "description": "Title text to render in the header.",
                    "type": "string"
                    "name": "headerSubtitle",
                    "description": "Subtitle Text to render in the header.",
                    "type": "string"
                    "name": "headerAttributionImage",
                    "description": "URL for attribution image or logo source (PNG/vector).",
                    "type": "string"
                    "name": "videoControlType",
                    "description": "The type of video control to use. Default is skip (foward and backwards).",
                    "type": "string",
                    "default": "skip"
                    "name": "videoSources",
                    "description": "Video single source or an array of sources. Videos will be in a playlist if multiple sources are provided.",
                    "type": "any"
                    "name": "sliderType",
                    "description": "Determinate for full control of the slider with transport control. Indeterminate is an ambient progress bar with animation.",
                    "type": "string",
                    "default": "determinate"
                    "name": "autoplay",
                    "type": "boolean",
                    "default": true,
                    "description": "Determines the starting state of the play/pause icon. This should match the autoplay state of the media playing component. Defaults to false. "
            "item": {
                "type": "Container",
                "height": "100vh",
                "width": "100vw",
                "bind": [
                        "name": "sliderThumbPosition",
                        "type": "number",
                        "value": 0
                        "name": "sliderActive",
                        "type": "boolean",
                        "value": false
                        "name": "videoProgressValue",
                        "type": "number",
                        "value": 0
                        "name": "videoTotalValue",
                        "type": "number",
                        "value": 0
                        "name": "videoControlsDisplay",
                        "type": "boolean",
                        "value": false
                "handleTick": [
                        "when": "${!sliderActive && displayFullscreen && videoControlsDisplay}",
                        "minimumDelay": 5000,
                        "description": "For video fullscreen view, hide video controls after 5 seconds of inactivity",
                        "commands": [
                                "type": "Parallel",
                                "sequencer": "ToggleVideoControlsSequencer",
                                "commands": [
                                        "type": "ToggleVideoOverlay",
                                        "componentId": "videoOverlay",
                                        "show": false
                                        "type": "ToggleVideoControls",
                                        "componentId": "videoHeader",
                                        "direction": "up",
                                        "show": false
                                        "componentId": "videoControls",
                                        "direction": "down",
                                        "show": false
                "items": [
                        "type": "AlexaBackground",
                        "id": "AlexaBackground",
                        "backgroundColor": "${backgroundColor}",
                        "backgroundImageSource": "${backgroundImageSource}"
                        "description": "Video container",
                        "height": "100%",
                        "width": "100%",
                        "position": "absolute",
                        "item": {
                            "type": "TouchWrapper",
                            "height": "100%",
                            "width": "100%",
                            "description": "Outer touch wrapper that brings up the controls",
                            "onPress": [
                                    "when": "${displayFullscreen}",
                                    "type": "Parallel",
                                    "commands": [
                                            "show": true
                                            "show": true
                                            "direction": "up",
                                            "show": true
                            "item": {
                                "height": "100%",
                                "width": "100%",
                                "alignItems": "center",
                                "item": {
                                    "type": "Video",
                                    "height": "${displayFullscreen ? '100%' : @videoHeight}",
                                    "width": "${displayFullscreen ? '100%' : @videoWidth}",
                                    "scale": "best-fill",
                                    "autoplay": true,
                                    "audioTrack": "foreground",
                                    "id": "videoPlayerId",
                                    "source": "${videoSources}",
                                    "top": "${displayFullscreen ? '0' : @videoPaddingTop}",
                                    "onPlay": [
                                            "type": "SetValue",
                                            "property": "videoTotalValue",
                                            "value": "${event.duration}"
                                    "onTrackUpdate": [
                                            "type": "SetValue",
                                    "onTimeUpdate": [
                                            "type": "SetValue",
                                            "property": "videoProgressValue",
                                            "value": "${event.currentTime}"
                                            "type": "SetValue",
                                            "componentId": "slider",
                                            "property": "progressValue",
                                            "value": "${videoProgressValue}"
                                            "type": "SetValue",
                                    "onTrackReady": [
                                            "type": "SetValue",
                                    "onTrackFail": [
                                            "type": "SetValue",
                                            "value": "0"
                        "description": "Header, slider, and controls container",
                        "height": "100%",
                        "width": "100%",
                        "items": [
                                "description": "Oveylay background for Video Controls",
                                "type": "Frame",
                                "id": "videoOverlay",
                                "height": "100%",
                                "width": "100%",
                                "backgroundColor": "${viewport.theme == 'light' ? '@colorWhite' : '@colorBlack'}",
                                "display": "none",
                                "opacity": 0
                                "when": "${@viewportProfileCategory != @hubRound}",
                                "type": "AlexaHeader",
                                "id": "videoHeader",
                                "opacity": "${displayFullscreen ? 0 : 1}",
                                "layoutDirection": "${environment.layoutDirection}",
                                "headerAttributionImage": "${headerAttributionImage}",
                                "headerTitle": "${headerTitle} ",
                                "headerSubtitle": "${headerSubtitle} ",
                                "headerAttributionPrimacy": true,
                                "width": "100%",
                                "theme": "${viewport.theme}"
                                "description": "Slider and controls",
                                "id": "videoControls",
                                "width": "100%",
                                "bottom": 0,
                                "items": [
                                        "when": "${sliderType != 'indeterminate'}",
                                        "item": [
                                                "type": "AlexaSlider",
                                                "id": "slider",
                                                "progressValue": "${videoProgressValue}",
                                                "totalValue": "${videoTotalValue}",
                                                "positionPropertyName": "sliderThumbPosition",
                                                "metadataDisplayed": true,
                                                "metadataPosition": "above_right",
                                                "width": "${@videoWidth + 5vw}",
                                                "paddingBottom": "@videoSliderPaddingBottom",
                                                "theme": "${viewport.theme}",
                                                "onUpCommand": [
                                                        "type": "ControlMedia",
                                                        "componentId": "videoPlayerId",
                                                        "command": "seek",
                                                        "value": "${sliderThumbPosition - videoProgressValue}"
                                                        "delay": "1000",
                                                        "type": "SetValue",
                                                        "property": "sliderActive",
                                                        "value": false
                                                "onMoveCommand": [
                                                        "type": "SetValue",
                                                        "value": true
                                                "onDownCommand": [
                                                        "type": "SetValue",
                                                        "value": true
                                                "type": "AlexaTransportControls",
                                                "mediaComponentId": "videoPlayerId",
                                                "playPauseToggleButtonId": "playPauseToggleButtonId",
                                                "primaryControlSize": "70dp",
                                                "secondaryControls": "${videoControlType}",
                                                "secondaryControlSize": "60dp",
                                                "autoplay": true,
                                                "bottom": "@videoControlPaddingBottom",
                                        "when": "${sliderType == 'indeterminate'}",
                                        "item": [
                                                "type": "AlexaProgressBar",
                                                "progressBarType": "indeterminate",
                                                "width": "@videoWidth",
        "AudioTransform": {
            "parameters": [
                    "name": "audioSource",
                    "type": "string"
            "items": [
                    "items": [
                            "type": "Text",
                            "id": "initialAPLAcomponent",
                            "speech": "${audioSource}"
    "mainTemplate": {
        "parameters": [
            "payload"
        "items": [
                "type": "VideoPlayer",
                "backgroundImageSource": "${payload.videoPlayerTemplateData.properties.backgroundImage}",
                "displayFullscreen": "${payload.videoPlayerTemplateData.properties.displayFullscreen}",
                "headerAttributionImage": "${payload.videoPlayerTemplateData.properties.logoUrl}",
                "headerTitle": "${payload.videoPlayerTemplateData.properties.headerTitle}",
                "headerSubtitle": "${payload.videoPlayerTemplateData.properties.headerSubtitle}",
                "videoControlType": "${payload.videoPlayerTemplateData.properties.videoControlType}",
                "videoSources": "${payload.videoPlayerTemplateData.properties.videoSources}",
                "sliderType": "${payload.videoPlayerTemplateData.properties.sliderType}"
                "type": "AudioTransform",
                "audioSource": "${payload.videoPlayerTemplateData.properties.outputAPLA.url}"
This is the datasource:
    "videoPlayerTemplateData": {
        "type": "object",
        "properties": {
            "backgroundImage": "",
            "displayFullscreen": true,
            "headerTitle": "",
            "headerSubtitle": "",
            "logoUrl": "https://my.png",
            "videoControlType": "jump10",
            "videoSources": [
                "https://my.mp4"
            "sliderType": "determinate"
        "transformers": [
                "template": "intialAPLA",
                "outputName": "outputAPLA",
                "transformer": "aplAudioToSpeech"
and this is the APLA source:
    "intialAPLA": {
        "type": "APLA",
        "version": "0.91",
        "mainTemplate": {
            "parameters": [
                "payload"
            "item": [
                    "type": "Mixer",
                    "items": [
                            "type": "Sequencer",
                            "items": [
                                    "type": "Audio",
                                    "description": "sound from bank",
                                    "source": "my.sound"
                                    "type": "Speech",
                                    "content": "myspeech "
                            "type": "Audio",
                            "source": "https://my.mp3",
                            "duration": "trimToParent",
                            "filter": [
                                    "type": "Volume",
                                    "amount": "50%"
                                    "type": "FadeOut",
                                    "duration": 2000
If I remove the video item from the main template the audio plays, so I know this is not an issue with the transformer. I've tried setting the speech attrbute of the video, in layouts, to be the transformer binding, and playing that onMount, but that doesn't work either.
It seems I can only play video or the audio, not both. This worked previously so I'm not sure what's changed.
Are you able to see why I can't return the video with the audio embedded?
apl
