Hi all,
we have a strange behaviour on Thermostat skill controller.
Using two different Thermostat, mode property (HEAT, COOL, AUTO. ON-OFF) can be set via vocal commands, but Alexa skill doesn't display setting menu tapping on current mode label.
Even more strange, the behaviuor is dfferent using two account based on US region and non-US regiom. Deep in detail
Case Thermostat 1:
the behaviuor is the same using on US region and non-US.
Alexa skill displays current mode value that IS NOT tappable (NO select menu with HEAT, COOL, AUTO. ON-OFF values)
Mode setting works fine triggered by vocal commands with both accounts.
Case Thermostat 2:
the behaviuor is the different using on US region and non-US.
Using US account, Alexa skill displays current mode value that IS tappable (select menu appears with HEAT, COOL, AUTO. ON-OFF).
Using non-US account, Alexa skill displays works like Tjermosta 1 case (NO select menu)
In this case also, mode setting works fine triggered by vocal commands with both accounts.
Discovery JSON follows below.
Could anyone help ?
Thanks a lot.
{ "event":{ "header":{ "namespace":"Alexa.Discovery", "name":"Discover.Response", "payloadVersion":"3", "messageId":"b2c7a4b4-0f56-40ae-b9ec-8922cf5b520d" }, "payload":{ "endpoints":[ { "endpointId":"012519AFT00017_8", "friendlyName":"termostato cucina", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "THERMOSTAT" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"targetSetpoint" }, { "name":"thermostatMode" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "supportsScheduling":true }, "interface":"Alexa.ThermostatController" }, { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"temperature" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.TemperatureSensor" } ] }, { "endpointId":"A32304FBB01136_1019", "friendlyName":"Contatto", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "CONTACT_SENSOR" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"detectionState" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.ContactSensor" } ] }, { "endpointId":"A32304FBB01136_1023", "friendlyName":"Angelone", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "LIGHT" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"powerState" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.PowerController" } ] }, { "endpointId":"A32304FBB01136_1030", "friendlyName":"Temperatura Clima", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "TEMPERATURE_SENSOR" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"temperature" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.TemperatureSensor" } ] }, { "endpointId":"A32304FBB01136_1035", "friendlyName":"Temperatura Sensori", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "TEMPERATURE_SENSOR" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"temperature" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.TemperatureSensor" } ] }, { "endpointId":"A32304FBB01136_1039", "friendlyName":"Contatto Clima", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "CONTACT_SENSOR" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"detectionState" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.ContactSensor" } ] }, { "endpointId":"A32304FBB01136_1040", "friendlyName":"Contatto Sensori", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "CONTACT_SENSOR" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"detectionState" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.ContactSensor" } ] }, { "endpointId":"A32304FBB01136_1041", "friendlyName":"OnOff Varie", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "SWITCH" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"powerState" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.PowerController" } ] }, { "endpointId":"A32304FBB01136_1010", "friendlyName":"Thermostat2", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "THERMOSTAT" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"targetSetpoint" }, { "name":"thermostatMode" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "supportsScheduling":true }, "interface":"Alexa.ThermostatController" }, { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"temperature" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.TemperatureSensor" } ] }, { "endpointId":"A32304FBB01136_1012", "friendlyName":"john", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "LIGHT" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"SetColor" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.ColorController" }, { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"brightness" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.BrightnessController" }, { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"powerState" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.PowerController" } ] }, { "endpointId":"A32304FBB01136_1013", "friendlyName":"Blind2", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "INTERIOR_BLIND" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "instance":"height", "properties":{ "supported":[ { "name":"rangeValue" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "supportedRange":{ "minimumValue":0, "maximumValue":100, "precision":5 }, "unitOfMeasure":"Alexa.Unit.Percent" }, "semantics":{ "actionMappings":[ { "actions":[ "Alexa.Actions.Open", "Alexa.Actions.Raise" ], "directive":{ "payload":{ "rangeValue":100 }, "name":"SetRangeValue" }, "@type":"ActionsToDirective" }, { "actions":[ "Alexa.Actions.Close", "Alexa.Actions.Lower" ], "directive":{ "payload":{ "rangeValue":0 }, "name":"SetRangeValue" }, "@type":"ActionsToDirective" } ], "stateMappings":[ { "states":[ "Alexa.States.Open" ], "range":{ "minimumValue":1, "maximumValue":100 }, "@type":"StatesToRange" }, { "states":[ "Alexa.States.Closed" ], "@type":"StatesToValue", "value":0 } ] }, "capabilityResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Setting.Opening" }, "@type":"asset" } ] }, "interface":"Alexa.RangeController" } ] }, { "endpointId":"A32304FBB01136_1014", "friendlyName":"Blind6", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "INTERIOR_BLIND" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "instance":"height", "properties":{ "supported":[ { "name":"rangeValue" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "supportedRange":{ "minimumValue":0, "maximumValue":100, "precision":5 }, "unitOfMeasure":"Alexa.Unit.Percent" }, "semantics":{ "actionMappings":[ { "actions":[ "Alexa.Actions.Open", "Alexa.Actions.Raise" ], "directive":{ "payload":{ "rangeValue":100 }, "name":"SetRangeValue" }, "@type":"ActionsToDirective" }, { "actions":[ "Alexa.Actions.Close", "Alexa.Actions.Lower" ], "directive":{ "payload":{ "rangeValue":0 }, "name":"SetRangeValue" }, "@type":"ActionsToDirective" } ], "stateMappings":[ { "states":[ "Alexa.States.Open" ], "range":{ "minimumValue":1, "maximumValue":100 }, "@type":"StatesToRange" }, { "states":[ "Alexa.States.Closed" ], "@type":"StatesToValue", "value":0 } ] }, "capabilityResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Setting.Opening" }, "@type":"asset" } ] }, "interface":"Alexa.RangeController" } ] }, { "endpointId":"A32304FBB01136_1003", "friendlyName":"garage", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "LIGHT" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"powerState" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.PowerController" } ] }, { "endpointId":"A32304FBB01136_1005", "friendlyName":"Thermostat3", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "THERMOSTAT" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"targetSetpoint" }, { "name":"thermostatMode" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "supportsScheduling":true }, "interface":"Alexa.ThermostatController" }, { "type":"AlexaInterface", "version":"3", "properties":{ "supported":[ { "name":"temperature" } ], "proactivelyReported":true, "retrievable":true }, "interface":"Alexa.TemperatureSensor" } ] }, { "endpointId":"A32304FBB01136_1006", "friendlyName":"Blind1", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "INTERIOR_BLIND" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "instance":"height", "properties":{ "supported":[ { "name":"rangeValue" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "supportedRange":{ "minimumValue":0, "maximumValue":100, "precision":5 }, "unitOfMeasure":"Alexa.Unit.Percent" }, "semantics":{ "actionMappings":[ { "actions":[ "Alexa.Actions.Open", "Alexa.Actions.Raise" ], "directive":{ "payload":{ "rangeValue":100 }, "name":"SetRangeValue" }, "@type":"ActionsToDirective" }, { "actions":[ "Alexa.Actions.Close", "Alexa.Actions.Lower" ], "directive":{ "payload":{ "rangeValue":0 }, "name":"SetRangeValue" }, "@type":"ActionsToDirective" } ], "stateMappings":[ { "states":[ "Alexa.States.Open" ], "range":{ "minimumValue":1, "maximumValue":100 }, "@type":"StatesToRange" }, { "states":[ "Alexa.States.Closed" ], "@type":"StatesToValue", "value":0 } ] }, "capabilityResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Setting.Opening" }, "@type":"asset" } ] }, "interface":"Alexa.RangeController" } ] }, { "endpointId":"A32304FBB01136_1007", "friendlyName":"Blind4", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "INTERIOR_BLIND" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "instance":"height", "properties":{ "supported":[ { "name":"mode" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "ordered":false, "supportedModes":[ { "value":"OPEN", "modeResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Value.Open" }, "@type":"asset" } ] } }, { "value":"CLOSED", "modeResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Value.Close" }, "@type":"asset" } ] } } ] }, "semantics":{ "actionMappings":[ { "actions":[ "Alexa.Actions.Open", "Alexa.Actions.Raise" ], "directive":{ "payload":{ "mode":"OPEN" }, "name":"SetMode" }, "@type":"ActionsToDirective" }, { "actions":[ "Alexa.Actions.Close", "Alexa.Actions.Lower" ], "directive":{ "payload":{ "mode":"CLOSED" }, "name":"SetMode" }, "@type":"ActionsToDirective" } ], "stateMappings":[ { "states":[ "Alexa.States.Open" ], "@type":"StatesToValue", "value":"OPEN" }, { "states":[ "Alexa.States.Closed" ], "@type":"StatesToValue", "value":"CLOSED" } ] }, "capabilityResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Setting.Opening" }, "@type":"asset" } ] }, "interface":"Alexa.ModeController" } ] }, { "endpointId":"A32304FBB01136_1016", "friendlyName":"Blind5", "description":"", "manufacturerName":"Manufacturer1", "displayCategories":[ "INTERIOR_BLIND" ], "capabilities":[ { "type":"AlexaInterface", "version":"3", "instance":"height", "properties":{ "supported":[ { "name":"mode" } ], "proactivelyReported":true, "retrievable":true }, "configuration":{ "ordered":false, "supportedModes":[ { "value":"OPEN", "modeResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Value.Open" }, "@type":"asset" } ] } }, { "value":"CLOSED", "modeResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Value.Close" }, "@type":"asset" } ] } } ] }, "semantics":{ "actionMappings":[ { "actions":[ "Alexa.Actions.Open", "Alexa.Actions.Raise" ], "directive":{ "payload":{ "mode":"OPEN" }, "name":"SetMode" }, "@type":"ActionsToDirective" }, { "actions":[ "Alexa.Actions.Close", "Alexa.Actions.Lower" ], "directive":{ "payload":{ "mode":"CLOSED" }, "name":"SetMode" }, "@type":"ActionsToDirective" } ], "stateMappings":[ { "states":[ "Alexa.States.Open" ], "@type":"StatesToValue", "value":"OPEN" }, { "states":[ "Alexa.States.Closed" ], "@type":"StatesToValue", "value":"CLOSED" } ] }, "capabilityResources":{ "friendlyNames":[ { "value":{ "assetId":"Alexa.Setting.Opening" }, "@type":"asset" } ] }, "interface":"Alexa.ModeController" } ] } ] } } }
