Sargius avatar image
Sargius asked
Amazon IAP Android PurchasingListener never called
I am trying to implement a subscription IAP on Android using the Amazon SDK (3.0.3). I made all things as described in Amazon appropriate documentation and their sample app and configured Amazon App Tester properly. However have no luck, I am getting no responses from PurchasingListener.
The ResponseReceiver has following structure in Manifest:
<receiver android:name = "com.amazon.device.iap.ResponseReceiver"
android:permission = "com.amazon.inapp.purchasing.Permission.NOTIFY"
android:exported="true">
<intent-filter>
<action android:name = "com.amazon.inapp.purchasing.NOTIFY" />
</intent-filter>
</receiver>
I register PurchaseListener in onCreate():
PurchasingService.registerListener(this.getApplicationContext(), purchasingListener);
Then make this call in onStart()
final Set<String> productSkus = new HashSet<String>();
for (final MySku mySku : MySku.values()) {
productSkus.add(mySku.getSku());
Log.d(TAG, "onStart: call getProductData for skus: " + mySku.getSku());
PurchasingService.getProductData(productSkus);
and finally in onResume():
PurchasingService.getUserData();
PurchasingService.getPurchaseUpdates(false);
Nothing from these call had returned any response. The Listener itself is registeres, as I can see in logs:
2022-07-27 18:50:14.791 11790-11790/......amazon D/d: Appstore SDK - Sandbox Mode: PurchasingListener registered: ......amazon.iap.SamplePurchasingListener@b3c6192
It is important to say, that if I am using old style receiver structure in Manifest (without "android:permission = "com.amazon.inapp.purchasing.Permission.NOTIFY" under <receiver tag), like here:
<intent-filter>
android:permission = "com.amazon.inapp.purchasing.Permission.NOTIFY"/>
</intent-filter>
</receiver>
, I am getting some responses, but very frustrating, since it is not what is expected to be, and this permission is highlighted with err:
Protecting an unsupported element with a permission is a no-op and potentially dangerous
The logs in this case show:
2022-07-27 19:07:11.673 12723-12723/.....amazon D/e: Appstore SDK - Sandbox Mode: sendGetUserDataRequest
2022-07-27 19:07:11.684 12723-12723/.....amazon D/e: Appstore SDK - Sandbox Mode: sendPurchaseUpdatesRequest/sendGetUserData first:e0656912-440d-4c7d-a864-0548028a803d
2022-07-27 19:07:11.743 12723-12723/.....amazon D/e: Appstore SDK - Sandbox Mode: handleResponse
2022-07-27 19:07:11.895 12723-12723/......amazon D/IAPListener: onProductDataResponse: RequestStatus (SUCCESSFUL)
2022-07-27 19:07:11.897 12723-12723/.....amazon D/IAPListener: onProductDataResponse: successful. The item data map in this response includes the valid SKUs
2022-07-27 19:07:11.897 12723-12723/antivirus.cleaner.fire.tablet.security.applock.booster.amazon D/IAPListener: onProductDataResponse: 0 unavailable skus
... and no other things are out there. Button for puchasing is dead and no other responses!
I don't minify the code with Proguard.
Testing device Amazon Fire 7 Tablet.
Target SDK - 32.
I stuck here for a long time, will be highly grateful if anyone could help me with this question!
Thank you in advance...
iapamazon appstoreandroidsdk
Levon@Amazon avatar image
Levon@Amazon answered
Hi Sargius,
I assume it's some sort of a setup / configuration error? I would suggest running a sample app included in the SDK to ensure that IAP works at all for you (it should).
As for your specific case:
- in the manifest, the permission should be attached to the receiver, and not to action. So the correct way is to have it just like it's described in the documentation:
<application>
      android:permission = "com.amazon.inapp.purchasing.Permission.NOTIFY">
    <intent-filter>
    </intent-filter>
  </receiver>
</application>
- ensure that you exported correct IAP items from your Developer Portal account, for the app that you are testing.
- could you please try to reduce the targetSdkVersion to something like 28, and see if it works for you?
