Marcos Peres avatar image
Marcos Peres asked
hello world sample not working
When I use the simulator to test the Hello World sample skill, it simply keeps running forever.
I did try the following:
  • Use Node.JS sample
  • Use Python sample
  • Tried to define the "Personalization"
  • Open by voice
  • Write "open my world" (the name I put for the skill)
  • Run the "Build Model" in the "Skill Invocation Name", "JSON Editor" and save (for both)
  • Run the "Deploy" in the "Code" tab after running the step above.
  • Tried another computer, another browser, and another router
  • Created a few skills from scratch with different names
  • Tried to import the sample from GitHub rather than "Continue with template"
  • Also tried to change the language and region
and.. it does not work.
It is worth mentioning that I did not change a word in the code.
testingalexa simulatortutorial
Joseph Kesselman avatar image
Joseph Kesselman answered
Try giving it a different name. With *EVERYONE* learning Alexa programming calling their experimental skill "Hello World" or some variant of that, Amazon has apparently been doing a poor job of keeping those from interfering with each other; I found that until I changed the name, my requests seemed to be going to another skill entirely.
Thank you Joseph, I did try to give a completely different name also. Still facing the same. It may be a silly small thing I'm doing wrong, and just can't find out.
Marcos Peres answered
UPDATE: I did try it once again using another computer I have with Linux, Firefox browser, and it works very well! Even using the Invocation "hello world".
Anyways, I'll keep it open just in case someone knows what can be wrong in Windows machines, using Chrome or Edge (* both Notifications and Advertisements are allowed in the configurations).
David Kleinberg avatar image
David Kleinberg answered
You mentioned that you "ran the Build Model in the Skill Invocation Name". But did you change the skill invocation name from "change me" to the skill name "hello world"?
Guillermo avatar image
Guillermo answered
I would believe using the simulator the topic "open my world", build model, " skilled invitation name" run off saving. The language tries to change the output that he did do what was arranged.
