Davide Benini avatar image
Davide Benini asked
LWA iOS framework not building on simulator on M1 Mac
The LWA framework does not build for the simulator on my M1 Mac mini.
Here is the error I get:
ld: in /Users/***/Downloads/LoginWithAmazon-3.1.2.1/samples/SampleLoginWithAmazonApp/Library/LoginWithAmazon.framework/LoginWithAmazon(AMZNAuthorizationManager.o), building for iOS Simulator, but linking in object file (/Users/***/Downloads/LoginWithAmazon-3.1.2.1/samples/SampleLoginWithAmazonApp/Library/LoginWithAmazon.framework/LoginWithAmazon(AMZNAuthorizationManager.o)) built for iOS, for architecture arm64
Please note that this error is generated in the very the sample application that you download with the LWA framework.
I have already downloaded the latest version of the framework (LoginWithAmazon-3.1.2.1) which supposedly fixes this bug, but I cannot build; I've been trying for weeks and given up a few times...
Any suggestions?
Cheers,
Davide
login with amazonios
Alejandro Uño avatar image Alejandro Uño commented ·
Hi, could you find any solution? I have the same error.
