I'm using Nodejs ask-sdk-core with a simple Lambda function written in Typescript:
export const handler: LambdaHandler = SkillBuilders.custom() .withSkillId("removed") .addRequestHandlers( LaunchRequestHandler, JingleIntentHandler, HelpIntentHandler, FallbackIntentHandler, CancelAndStopIntentHandler, SessionEndedRequestHandler ) .addErrorHandlers(errorHandler) .lambda();
I'm then using amazon/aws-lambda-nodejs:latest as my base image and self-hosting in a Rancher K8s cluster.
Testing from the Alexa dev console works just fine but when I got to certify the skill I'm getting the error "Skill End Point Not Validating The Signatures." However everything I've read seems to indicate that between the RIC bundled with the Docker image and the Nodejs lambda() function this should automatically be taken care of and I would just need to check the skillID.
https://developer.amazon.com/en-US/docs/alexa/custom-skills/handle-requests-sent-by-alexa.html#get-the-skill-id-for-your-skill
What am I not understanding?
