Shawn Haywood avatar image
Shawn Haywood asked
Zigbee Motion Sensor Routine does not run
Hello. I successfully added a ZigBee motion sensor to a ZigBee hub using the Tuya App, which was also recognized as alarm motion device by Alexa. I can view the device's activity (motion detection) in Alexa. For example, the Alexa App device section shows when motion occurs and records the activity history.
I tried several times to create a routine that broadcasts a voice message from a home echo device when device motion is detected. However, the trigger (motion) never activates the routine. I've tried several times - even removing the device, reinstalling it and recreating the routines. Activity (motion) is never recorded in the routine's history section of Alexa.
Routine Setup:
When: Motion Sensor detects motion
Anytime
Alexa Action: Say: "Mailbox is open"
Any ideas? Other routines work fine with other types of devices on network.
amazon device messagingroutineszigbee setup
