池戸 憲夫 avatar image
池戸 憲夫 asked
Doesn't complete the setup process of ACK device.
I made original circuit board that using esp32 pico v3 zero and test it to make original device using ACK.
On the test, I use tutorials "Prototype Your product"(https://developer.amazon.com/ja-JP/docs/alexa/ack/create-virtual-product.html)
But Step5, when I scan QR code, Alexa app show this view immediately. And it doesn't show wifi settings.
Of course, I already finished Step1 ~ Step4 completely. And I confirmed the system has the BLE data.
Is it App's bug? or Error of the original circuit board?
My development environment is...
- iPhone12 pro max , iOS:15.1.1
- Alexa app version: 2.2.454039
- ACK module: ESP32-pico-v3-zero
- MCU: RP2040
Note: Original board is not connect the reset signal to MCU.
Another pin assign is same as arduino zero.
alexaappwi-fi setup
Veera Manideep Guntupalli avatar image
Veera Manideep Guntupalli answered
In step5,
1) can you confirm, you choose "development device" and then "ACK" right?
2) can you make sure the Bluetooth device or the ACK module didn't timeout during the registration? you might have to restart the ACK module if Bluetooth times out.
https://developer.amazon.com/ja-JP/docs/alexa/ack/register.html
Thank you for your reply.
I confirmed process again. 1) is incorrect in my process. I selected "Espressif".
When I have been choosed "ACK", set up process was completed!
