Alex Sensor avatar image
Alex Sensor asked
skill working on mobile app and test dev console but not on echo show 5
currently testing skills and none of them i do are working on my actual linked device Echo Show 5 (2nd Gen, 2021 release)
decided to do the "Hello world" skill in the dev console and it's working fine on the mobile app & test panel in the dev console, however it isn't working at all on my linked device. currently set it up with beta test (yes, everything is using the same email & the language/region is the same)
Things I've tried:
  • Using the mobile app to enable it
  • Testing it on the dev portal and mobile alexa (worked, but still not working on echo)
  • Factory resetting the Echo Show 5
  • Creating a new skill
  • Restarting the echo
  • Language is the same on everything as well as the region
  • Email is the same on everything
  • Disabling the skill and re-enabling it on the mobile app
  • WiFi is the same on everything
  • Changing the skill name & launch phrase
yeah so pretty much nothing is working
alexa responds with "Sorry, I couldn't launch it" when i say "launch [skill name/phrase here]"
other public skills are working, just not mine that i'm doing with the beta test feature
any help is appreciated, thank you.
alexa skills kitalexanodejsskills
Andy Whitworth avatar image
Andy Whitworth answered
Have you checked that the dev version of your skill is enabled ? This doesn't always happen by default and can cause the issues you mention i.e. works in dev console but not on a real device.
Check the Alexa app, find your skill (the dev version) and ensure it's enabled.
