Jeremy avatar image
Jeremy asked
Non-Retrievable Generic Controllers As Window Blinds Alexa App Integration Issue
If an endpoint is set as OTHER display category, any of its non-retrievable (command only) generic capability controls would be available along side retrievable ones in the Alexa app.
However, the same configuration as INTERIOR_BLIND or EXTERIOR_BLIND display category would result in no controls being available in the Alexa app going directly to the settings page.
This is an issue when modeling a connected blind that also supports, besides percent values, one way commands to change directions (Up/Down/Stop).
Expected controls available in Alexa app as INTERIOR_BLIND:
Here is a discovery example of such endpoint:
  "endpointId": "Blind",
  "manufacturerName": "manufacturer",
  "description": "description",
  "friendlyName": "Blind",
  "displayCategories": [
    "INTERIOR_BLIND"
  "cookie": {},
  "capabilities": [
      "type": "AlexaInterface",
      "interface": "Alexa.ModeController",
      "instance": "Blind.Command",
      "version": "3",
      "properties": {
        "supported": [
            "name": "mode"
        "proactivelyReported": false,
        "retrievable": false,
        "nonControllable": false
      "capabilityResources": {
        "friendlyNames": [
            "@type": "text",
            "value": {
              "text": "Command",
              "locale": "en-US"
      "configuration": {
        "ordered": false,
        "supportedModes": [
            "value": "UP",
            "modeResources": {
              "friendlyNames": [
                  "@type": "text",
                  "value": {
                    "text": "Up",
                    "locale": "en-US"
            "value": "DOWN",
            "modeResources": {
              "friendlyNames": [
                  "@type": "text",
                  "value": {
                    "text": "Down",
                    "locale": "en-US"
            "value": "STOP",
            "modeResources": {
              "friendlyNames": [
                  "@type": "text",
                  "value": {
                    "text": "Stop",
                    "locale": "en-US"
      "interface": "Alexa.RangeController",
      "instance": "Blind.Opening",
      "version": "3",
      "properties": {
        "supported": [
            "name": "rangeValue"
        "retrievable": true,
        "friendlyNames": [
            "@type": "asset",
            "value": {
              "assetId": "Alexa.Setting.Opening"
      "configuration": {
        "supportedRange": {
          "minimumValue": 0,
          "maximumValue": 100,
          "precision": 1
        "unitOfMeasure": "Alexa.Unit.Percent"
      "semantics": {
        "actionMappings": [
            "@type": "ActionsToDirective",
            "actions": [
              "Alexa.Actions.Close"
            "directive": {
              "name": "SetRangeValue",
              "payload": {
                "rangeValue": 0
            "actions": [
              "Alexa.Actions.Open"
            "directive": {
              "payload": {
                "rangeValue": 100
        "stateMappings": [
            "@type": "StatesToValue",
            "states": [
              "Alexa.States.Closed"
            "value": 0
            "@type": "StatesToRange",
            "states": [
              "Alexa.States.Open"
            "range": {
              "minimumValue": 1,
              "maximumValue": 100
      "interface": "Alexa.EndpointHealth",
      "version": "3",
      "properties": {
        "supported": [
            "name": "connectivity"
        "retrievable": true
      "interface": "Alexa",
      "version": "3"
alexa smart home
Chihiro@Amazon avatar image
Chihiro@Amazon answered
Hi Jeremy,
It looks you are already in touch with us on a contact us case. We will follow up with you directly on the case for this issue.
Jeremy avatar image
Jeremy answered
I actually resolved this issue by tweaking the discovery response of my skill to not include the properties object on non-retrievable capabilities (command only) since these will not report a property state. Everything is working nicely based on my testing.
    "INTERIOR_BLIND"
  "cookie": {},
  "capabilities": [
      "version": "3",
        "friendlyNames": [
            "@type": "text",
            "value": {
              "text": "Command",
              "locale": "en-US"
      "configuration": {
        "ordered": false,
        "supportedModes": [
            "value": "UP",
            "modeResources": {
              "friendlyNames": [
                  "@type": "text",
                  "value": {
                    "text": "Up",
                    "locale": "en-US"
            "value": "DOWN",
            "modeResources": {
              "friendlyNames": [
                  "@type": "text",
                  "value": {
                    "text": "Down",
                    "locale": "en-US"
            "value": "STOP",
            "modeResources": {
              "friendlyNames": [
                  "@type": "text",
                  "value": {
                    "text": "Stop",
                    "locale": "en-US"
      "version": "3",
      "properties": {
        "supported": [
        "friendlyNames": [
            "@type": "asset",
            "value": {
      "configuration": {
        "supportedRange": {
          "minimumValue": 0,
          "precision": 1
      "semantics": {
        "actionMappings": [
            "actions": [
            "directive": {
              "payload": {
                "rangeValue": 0
            "actions": [
            "directive": {
              "payload": {
                "rangeValue": 100
        "stateMappings": [
            "states": [
            "value": 0
            "states": [
              "Alexa.States.Open"
            "range": {
              "minimumValue": 1,
              "maximumValue": 100
      "version": "3",
      "properties": {
        "supported": [
        "retrievable": true
      "version": "3"
