Oblo Living avatar image
Oblo Living asked
Access Token Request - invalid_client - 401 status
Keep getting "error": "invalid_client" but set everything like official example:
POST /auth/o2/token HTTP/1.1
Host: api.amazon.com
Content-Type: application/x-www-form-urlencoded;charset=UTF-8
grant_type=authorization_code
&code=amazon authorization code
&client_id=yourClientId            ---> is 'Alexa Client Id'?
&client_secret=yourClientSecret    ---> is 'Alexa Client Secret'?
&redirect_uri=yourRedirectUri
Authorization is set to: Bearer Token czzCaGRSa3F0MzpnWDFmQmF0M2JW
What am I doing wrong?
Please help!
Thanks in advance!
alexa
Andy Whitworth avatar image
Andy Whitworth answered
Stepping back a bit, what is the purpose you're looking to obtain an access token for ?
5 comments
Building App-to-app-account-linking...
OK, the Amazon documentation says:
Client ID
The client ID that the developer console provides when you enable app-to-app account linking in the developer console.
Client secret
The client secret that the developer console provides when you enable app-to-app account linking in the developer console.
Are they the values you're supplying ?
And for
You're supplying the auth code you've received ?
Not sure if you need the Authorization header either, the Amazon docs I'm looking at don't mention it.
Yes, 'code' is the value from response from LWA request.
If no authorization header is set, or other authorization header type - I get "error_description": "Malformed request", "error": "invalid_request".
If authorization header is set as 'Bearer Token' than "error": "invalid_client".
Also tried with Client ID and Client secret from 'Security Profile Management > My profile...', and got the same error like with Amazon Client Id and Amazon Client secret.
