José avatar image
José asked
Localisation & array
Hi everyone!!!
I have the next issue; my alexa's skill have a file localisation.js to manage the language, into it i have an array like this:
 questions: [
'question 1',
'question 2',
'question 3',
'question 4'
How i can do to get questions size (number of indexes) in index.js to asingation??
i tried
 const quizSize = 'questions'.length
but i get the size of questions like string.
Thanks a lot for read and answer.
alexa skillsalexa hosted skillslocales
Andy Whitworth avatar image
Andy Whitworth answered
Remove the quotes:
const quizSize = questions.length;
With the quotes, you're getting the length of the string 'questions' as you've found.
5 comments
José avatar image José commented ·
I already tried that Andy. if i remove quotes, get this:
thanks anyway...
Andy Whitworth avatar image Andy Whitworth José commented ·
Where did VAL_REL come from ? In your first post the variable was named questions.
Where have you defined VAL_REL in your code ?
José avatar image José Andy Whitworth commented ·
ok np, questions or VAL_REL, both are arrays, called from localisation.js file. I need get them size.
José avatar image
José answered
I got it!!! it was only necessary to implement the following function to retrieve the array as an object and then obtain its size.
in index.js:
function r(template) {
  return i18n.t(template, { returnObjects: true });
To get the array size:
quizSize = r('questions').length;
José avatar image
José answered
Thanks Andy.
