aditya patil avatar image
aditya patil asked
Not able generate token for proactive events, getting "The request has an invalid parameter : scope"
alexa
Andy Whitworth avatar image
Andy Whitworth answered
Perhaps you could let us know how you are attempting to generate the token ?
In code (if so, what language) ? Using curl (if so, show us the curl expression) ?
Give us some information / code snippets etc and we can help.
aditya patil answered
Sure, thanx for responsre.
I have tried using postman and curl.
Using postman:
POST /auth/o2/token HTTP/1.1
Host: api.amazon.com
Content-Type: application/x-www-form-urlencoded
grant_type=client_credentials&client_id=(clientID)&client_secret=(clientSecret)&scope=alexa::proactive_events
Using curl:,
curl -i -XPOST -H 'Content-Type: application/x-www-form-urlencoded' -d 'grant_type=client_credentials&client_id=xxxx&client_secret=yyyy&scope=alexa::proactive_events' https://api.amazon.com/auth/o2/token
For both i received this error:
{"error_description":"The request has an invalid parameter : scope","error":"invalid_scope"}
Just tried using curl and a postman-like tool, both work fine and give me an access token.
It would seem to me that you're not providing a scope value of alexa::proactive_events, is the scope value *exactly* alexa::proactive_events ? Must have the alexa:: prefix, with two colons.
Paste up the command line request you're sending (the *exact* command) and the response you get. Blank out the client_id and secret used when posting up.
Thanx for response sir, i checked manfiest schema for this. It needs some changes for proactive events, so its working now.
Thank you for your quick response and valuable time.
