Mast avatar image
Mast asked
it keeps saying "You just triggered RedoBestCoderIntent". how can i fix this?
# -*- coding: utf-8 -*-
# This sample demonstrates handling intents from an Alexa skill using the Alexa Skills Kit SDK for Python.
# Please visit https://alexa.design/cookbook for additional examples on implementing slots, dialog management,
# session persistence, api calls, and more.
# This sample is built using the handler classes approach in skill builder.
import logging
import ask_sdk_core.utils as ask_utils
from ask_sdk_core.skill_builder import SkillBuilder
from ask_sdk_core.dispatch_components import AbstractRequestHandler
from ask_sdk_core.dispatch_components import AbstractExceptionHandler
from ask_sdk_core.handler_input import HandlerInput
from ask_sdk_model import Response
logger = logging.getLogger(__name__)
logger.setLevel(logging.INFO)
class LaunchRequestHandler(AbstractRequestHandler):
    """Handler for Skill Launch."""
    def can_handle(self, handler_input):
        # type: (HandlerInput) -> bool
        return ask_utils.is_request_type("LaunchRequest")(handler_input)
    def handle(self, handler_input):
        # type: (HandlerInput) -> Response
        speak_output = "Welcome, you can say Hello or Help. Which would you like to try?"
        return (
            handler_input.response_builder
                .speak(speak_output)
                .ask(speak_output)
                .response
class RedoBestCoderHandler(AbstractRequestHandler):
        return ask_utils.is_intent_name("RedoBestCoderIntent")(handler_input)
    def  handle(self,handler_input):
        speak_output = "Test success"
        return(
            handler_input.response_builder.speak(speak_output).response
class HelloWorldIntentHandler(AbstractRequestHandler):
    """Handler for Hello World Intent."""
        return ask_utils.is_intent_name("HelloWorldIntent")(handler_input)
        speak_output = "Hello World!"
        return (
                # .ask("add a reprompt if you want to keep the session open for the user to respond")
                .response
class HelpIntentHandler(AbstractRequestHandler):
    """Handler for Help Intent."""
        return ask_utils.is_intent_name("AMAZON.HelpIntent")(handler_input)
        speak_output = "You can say hello to me! How can I help?"
        return (
                .ask(speak_output)
                .response
class CancelOrStopIntentHandler(AbstractRequestHandler):
    """Single handler for Cancel and Stop Intent."""
        return (ask_utils.is_intent_name("AMAZON.CancelIntent")(handler_input) or
                ask_utils.is_intent_name("AMAZON.StopIntent")(handler_input))
        speak_output = "Goodbye!"
        return (
                .response
class FallbackIntentHandler(AbstractRequestHandler):
    """Single handler for Fallback Intent."""
        return ask_utils.is_intent_name("AMAZON.FallbackIntent")(handler_input)
        logger.info("In FallbackIntentHandler")
        speech = "Hmm, I'm not sure. You can say Hello or Help. What would you like to do?"
        reprompt = "I didn't catch that. What can I help you with?"
        return handler_input.response_builder.speak(speech).ask(reprompt).response
class SessionEndedRequestHandler(AbstractRequestHandler):
    """Handler for Session End."""
        return ask_utils.is_request_type("SessionEndedRequest")(handler_input)
        # Any cleanup logic goes here.
        return handler_input.response_builder.response
class IntentReflectorHandler(AbstractRequestHandler):
    """The intent reflector is used for interaction model testing and debugging.
    It will simply repeat the intent the user said. You can create custom handlers
    for your intents by defining them above, then also adding them to the request
    handler chain below.
        return ask_utils.is_request_type("IntentRequest")(handler_input)
        intent_name = ask_utils.get_intent_name(handler_input)
        speak_output = "You just triggered " + intent_name + "."
        return (
                .response
class CatchAllExceptionHandler(AbstractExceptionHandler):
    """Generic error handling to capture any syntax or routing errors. If you receive an error
    stating the request handler chain is not found, you have not implemented a handler for
    the intent being invoked or included it in the skill builder below.
    def can_handle(self, handler_input, exception):
        # type: (HandlerInput, Exception) -> bool
        return True
    def handle(self, handler_input, exception):
        # type: (HandlerInput, Exception) -> Response
        logger.error(exception, exc_info=True)
        speak_output = "Sorry, I had trouble doing what you asked. Please try again."
        return (
                .ask(speak_output)
                .response
# The SkillBuilder object acts as the entry point for your skill, routing all request and response
# payloads to the handlers above. Make sure any new handlers or interceptors you've
# defined are included below. The order matters - they're processed top to bottom.
sb = SkillBuilder()
sb.add_request_handler(LaunchRequestHandler())
sb.add_request_handler(RedoBestCoderHandler())
sb.add_request_handler(HelloWorldIntentHandler())
sb.add_request_handler(HelpIntentHandler())
sb.add_request_handler(CancelOrStopIntentHandler())
sb.add_request_handler(FallbackIntentHandler())
sb.add_request_handler(SessionEndedRequestHandler())
sb.add_request_handler(IntentReflectorHandler()) # make sure IntentReflectorHandler is last so it doesn't override your custom intent handlers
sb.add_exception_handler(CatchAllExceptionHandler())
lambda_handler = sb.lambda_handler()
intentspythonskills
Jason@Amazon avatar image
Jason@Amazon answered
You need to add the RedoBestCoderHandler handler to request handlers at the bottom of your code above the following line:
  1. sb.add_request_handler(IntentReflectorHandler()) # make sure IntentReflectorHandler is last so it doesn't override your custom intent handlers
