Josh Cooke avatar image
Josh Cooke asked
Implementing LWA in a C# Steam app. Stuck trying to use access token.
Been struggling my way through this with no SDK and no real documentation - only the TV & Other Device docs.
Requesting a code and polling for an access token went well.
However I'm now on STEP 5 of this guide (https://developer.amazon.com/docs/login-with-amazon/customer-profile-other-platforms-cbl-docs.html) and the format is very different to the previous steps.
I gather the endpoint is
"https://api.amazon.com/user/profile"
but it's not happy with any fields I try to give it (trying each of these one at a time)
form.AddField( "access_token", token );
form.AddField( "x-amz-access-token", token );
form.AddField( "Authorization", "bearer " + token );
They all give me the same response of
<UnknownOperationException/>
HTTP/1.1 404 Not Found
Anyone know what I'm doing wrong?
Thanks,
Josh
login with amazon
Josh Cooke answered
The answer was simply that for the previous steps a POST is needed but for retrieving profile info a GET should be used.
