Hicham EL IFQAOUI avatar image
Hicham EL IFQAOUI asked
smart home Skill linked to Lambda function, not working
I create a lambda function (for Home Assistant), which can discover all my devices. all the process works well, the Logs of test result discover all my devices, automations and scripts.
below the result (partial) returned by your function execution:
  "event": {
    "header": {
      "namespace": "Alexa.Discovery",
      "name": "Discover.Response",
      "messageId": "58794a28-aecd-4232-b359-645d7bec0b33",
      "payloadVersion": "3"
    "payload": {
      "endpoints": [
          "displayCategories": null,
          "cookie": {},
          "endpointId": "binary_sensor#updater",
          "friendlyName": "Updater",
          "description": "binary_sensor.updater via Home Assistant",
          "manufacturerName": "Home Assistant",
          "additionalAttributes": {
            "manufacturer": "Home Assistant",
            "model": "binary_sensor",
            "softwareVersion": "2021.8.7",
            "customIdentifier": "-binary_sensor.updater"
          "capabilities": [
              "type": "AlexaInterface",
              "interface": "Alexa.EndpointHealth",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "connectivity"
                "proactivelyReported": true,
                "retrievable": true
              "interface": "Alexa",
              "version": "3"
          "displayCategories": [
            "CAMERA"
          "cookie": {},
          "endpointId": "camera#mjpeg_camera",
          "friendlyName": "Mjpeg Camera",
          "description": "camera.mjpeg_camera via Home Assistant",
            "model": "camera",
            "customIdentifier": "-camera.mjpeg_camera"
Then, i create a Alexa skill which i linked to my lambda function, the linked work. when i come back to Alexa app, i add the new skill but once the discover finished, Alexa did not find any devices!!
in alexa developper console the region : https://pitangui.amazon.com/
and in AWS, the region is set to virgina
when i try to access with https (https://<BASE_URL:MY-PORT>/api/alexa/smart_home i get 405: Method Not Allowed
Did i miss something? why i didnot work in alexa app?
Thanks for help
Hicham
alexa smart homelambda
Hicham EL IFQAOUI answered
After checking and do again all over, i think this is a region setting issue, Could you indicate which region should i set for it?
