Alexander Rahn avatar image
Alexander Rahn asked
Alexa CBT Test: Failed Test due to DeepQuery=True
My colleagues and I have been working to fix a reported issue on our Amazon Alexa CBT Test regarding the value “DeepQuery=true”.
Our code has been modified, so that every state change is reported automatically and all the used interfaces have the properties “proactivelyReported” and “retrievable” set to true.
As has been suggested by the WWA-Support we used the Smart Home Debugger of the Developer Console to validate the ReportEvents (e.g. Discovery or ChangeReport) and we checked the state of our device on the “View Device State” page (both pages are referenced on: https://developer.amazon.com/en-US/docs/alexa/smarthome/debug-your-smart-home-skill.html).
For debugging purposes we scaled our device capabilities down to just the PowerController. The AddOrUpdateReport of Alexa.Discovery looks to our eyes now exactly as expected/documented. Same goes for the ChangeReport, which we proactively send right after the AddOrUpdateReport (Two sample-Reports for both are provided at the end).
Unfortunately we are still faced with the issue, that “DeepQuery=true” on the “View Device State” page.
If we set the interface property “retrievable” to false, “DeepQuery=false”, but the Alexa-App does not retain the current state of the device. In this configuration the Alexa-App can only be used to send commands, which unfortunately will lead to other test cases to fail.
Does anyone know how to solve this issue?
How can we set “proactivelyReported” and “retrievable” to true and have “DeepQuery=false”?
Any help would be greatly appreciated and I will gladly provide more informations if needed.
Sample AddOrUpdateReport from Smart Home Debugger
    "header": {
        "namespace": "SkillDebugger",
        "name": "CaptureDebuggingInfo",
        "messageId": "05b030fb-6393-4ae0-80d0-47fc27876f0e"
    "payload": {
        "skillId": "amzn1.ask.skill.055ca62d-3cf8-4f51-a683-9a98b36f4637",
        "timestamp": "2021-09-09T13:28:21.629Z",
        "dialogRequestId": null,
        "skillRequestId": null,
        "type": "SmartHomeAddOrUpdateReportSuccess",
        "content": {
            "addOrUpdateReport": {
                "event": {
                    "header": {
                        "namespace": "Alexa.Discovery",
                        "name": "AddOrUpdateReport",
                        "messageId": "2458b969-7c3e-47e2-ab0b-6e13a999be76",
                        "payloadVersion": "3"
                    "payload": {
                        "endpoints": [
                                "manufacturerName": "Our Company Name",
                                "description": "Our Product Name",
                                "endpointId": "device--cb12b420-1171-11ec-81f3-cb34e87ea438",
                                "friendlyName": "Lampe 1",
                                "capabilities": [
                                        "type": "AlexaInterface",
                                        "version": "3",
                                        "interface": "Alexa.PowerController",
                                        "properties": {
                                            "supported": [
                                                    "name": "powerState"
                                            "proactivelyReported": true,
                                            "retrievable": true
                                        "interface": "Alexa",
                                        "version": "3"
                                "displayCategories": [
                                    "LIGHT"
                                "connections": [],
                                "relationships": {},
                                "cookie": {}
                        "scope": null
Sample ChangeReport from Smart Home Debugger
    "header": {
        "messageId": "194a96a1-6747-46ba-8751-5c9ef715fd34"
    "payload": {
        "timestamp": "2021-09-09T13:28:23.227Z",
        "type": "SmartHomeChangeReportSuccess",
        "content": {
            "changeReport": {
                "event": {
                    "header": {
                        "namespace": "Alexa",
                        "name": "ChangeReport",
                        "messageId": "8972e386-9622-40e6-85e7-1a7d81c79c8a",
                    "endpoint": {
                        "scope": null,
                    "payload": {
                        "change": {
                            "cause": {
                                "type": "APP_INTERACTION"
                            "properties": [
                                    "namespace": "Alexa.PowerController",
                                    "name": "powerState",
                                    "value": "ON",
                                    "timeOfSample": "2021-09-09T13:28:18.088Z",
                                    "uncertaintyInMilliseconds": 500
                "context": {
                    "properties": []
alexa skills kitalexa smart homealexaapp
Jason@Amazon avatar image
Jason@Amazon answered
As this issue is specific to your account, please file a contact us here where we will be able to assist further.
3 comments
Hello Jason,
thank you for your response.
We already contacted the Alexa Developer Support through the form you shared - in fact we asked the same question that is posted here, just truncated in size to fit the character limitations. Here the CaseID: 8815743371.
My colleges and I are in exchange with the support since 1th of September under this CaseID. As suggested by them, we used the official Smart Home Debugging tools and studied the documentation carefully. But since our outputs look as expected/documented, we now really need more expertise beyond pointing us to the documentation.
Any further help would be greatly appreciated.
If you've reached out to us then they're still your best chance of support from our standpoint. I recommend reaching again on your case and providing a link to this post just so they know that you're still facing issues there - if you've followed the documentation and can't figure it out, let us know there and our team can investigate further.
Thank you Jason for your honest feedback. I will follow your advice and focus on reaching out to the amazon/alexa team via the Developer Support.
