Based on implementations I've seen the mode of the thermostat isn't controllable from the Alexa App. I can set the temperature but I can't change between HEAT, COOL, or AUTO. I have to either use voice control or control the device directly. Is this correct or is there a way to enable control from the Alexa App?
Do I need to declare an additional display type? Or is this a design choice?
