aimore avatar image
aimore asked
Skill-Device Association Event (SDAE) error:invalid_scope error_description
We're working on Frustration Free Setup FFS (Wi-Fi Simple Setup),
We follow this document:
https://developer.amazon.com/docs/frustration-free-setup/wi-fi-provisionee-app-and-backend-integration-guide.html#certif Ication,
The Skill-Device Association Event (SDAE) API requires an access token
However, we encountered a problem when trying to obtain the token:
error:invalid_scope error_description:The request has an invalid parameter : scope.
Does this scope need your approval to use?
Our skill id is : amzn1.ask.skill.619322cf-22bd-42dd-8f1c-19ef4acb5a4e
The scope is: alexa::device_association_report:write
Here is the post data:
POST /auth/o2/token HTTP/1.1
Host: api.amazon.com
Content-Type: application/json
Content-Body:
client_id:amzn1.application-oa2-client.xxx
client_secret:xxx
grant_type:client_credentials
scope:alexa::device_association_report:write
I have sent an email to ffs-support@amazon.com, but have not received a reply so far.
Please help us look at this problem,
Thank you very much.
sdae
Anand@Amazon avatar image
Anand@Amazon answered
Hello there
It looks like you have already raised contact us case with us. Please refer this case Id # 8661072701 for all future communications.
Hi,can you share the solution, we encouter this problem too. thank you
