Harshal Belan avatar image
Harshal Belan asked
Controlling multiple LED/Output
In example project one LED/Output is controlled. Can someone post an example or mechanism to control multiple output/LED. Project details-Using expressif ACK developement board with arduino zero.
api
3 comments
ACK Hardware is controlled through HMCU. Refer to this guide to add functionality to your product.
Harshal Belan avatar image Harshal Belan Veera Manideep Guntupalli ·
Thank you for the reply. I have gone through guide for adding new functionality. I am not able add capabilities like mode or range. If capabilities is added other then brightness and power then device is not getting provisioning , I am not able to add device in Alexa App. Can you please guide regarding this issue.
If incorrect capabilities are added to your product, it will affect the registration. Please refer to mode and range controller guide for the JSON format.
What is the error code you see during registration?
