I have my own smart home implementation using AVS scripts.
On June 9th I updated my template for BLINDS to include addtional commands using ModeController.
I added a couple of devices using the same template.
This was working fine. I could use voice commands for all the new commands on all devices.
This week I wanted to add some more devices using the same template.
However for the new devices Alexa won't accept the voice commands anymore.
I can see the different modes in the App and I am able to select them there.
It's just not working for the voice commands.
On the previously added devices the voice commands are still working.
I tried deleting one of the old devices and recreating it, resulting in the same problem.
This is my template:
{ "event": { "header": { "namespace": "Alexa.Discovery", "name": "AddOrUpdateReport", "messageId": "e6bd8529-efe3-70db-d370-e51ccf22aefc", "eventCorrelationToken": "0815", "payloadVersion": "3" }, "payload": { "endpoints": [ { "endpointId": "1995", "manufacturerName": "Edomi", "description": "Jalousie Küchentür Terrasse", "friendlyName": "Jalousie Küchentür", "displayCategories": [ "EXTERIOR_BLIND" ], "cookie": {}, "capabilities": [ { "type": "AlexaInterface", "interface": "Alexa.ModeController", "instance": "Blind.Mode", "version": "3", "properties": { "supported": [ { "name": "mode" } ], "retrievable": true, "proactivelyReported": true, "nonControllable": false }, "capabilityResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Betriebsart", "locale": "de-DE" } } ] }, "configuration": { "ordered": false, "supportedModes": [ { "value": "stop", "modeResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Stopp", "locale": "de-DE" } } ] } }, { "value": "stepUp", "modeResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Heller", "locale": "de-DE" } } ] } }, { "value": "stepDown", "modeResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Dunkler", "locale": "de-DE" } } ] } }, { "value": "auto", "modeResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Automatik", "locale": "de-DE" } }, { "@type": "text", "value": { "text": "Auto", "locale": "de-DE" } }, { "@type": "text", "value": { "text": "Automatikbetrieb", "locale": "de-DE" } } ] } }, { "value": "manual", "modeResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Handbetrieb", "locale": "de-DE" } }, { "@type": "text", "value": { "text": "Hand", "locale": "de-DE" } }, { "@type": "text", "value": { "text": "Manuell", "locale": "de-DE" } } ] } }, { "value": "disable", "modeResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Sperren", "locale": "de-DE" } }, { "@type": "text", "value": { "text": "Sperre", "locale": "de-DE" } } ] } }, { "value": "enable", "modeResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Freigeben", "locale": "de-DE" } }, { "@type": "text", "value": { "text": "Freigabe", "locale": "de-DE" } }, { "@type": "text", "value": { "text": "Entsperren", "locale": "de-DE" } } ] } } ] } }, { "type": "AlexaInterface", "interface": "Alexa.RangeController", "instance": "Blind.Height", "version": "3", "properties": { "supported": [ { "name": "opening" } ], "proactivelyReported": true, "retrievable": true }, "capabilityResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Behanghöhe", "locale": "de-DE" } } ] }, "configuration": { "supportedRange": { "minimumValue": 0, "maximumValue": 100, "precision": 1 }, "unitOfMeasure": "Alexa.Unit.Percent" }, "semantics": { "actionMappings": [ { "@type": "ActionsToDirective", "actions": [ "Alexa.Actions.Close" ], "directive": { "name": "SetRangeValue", "payload": { "rangeValue": 100 } } }, { "@type": "ActionsToDirective", "actions": [ "Alexa.Actions.Open" ], "directive": { "name": "SetRangeValue", "payload": { "rangeValue": 0 } } }, { "@type": "ActionsToDirective", "actions": [ "Alexa.Actions.Lower" ], "directive": { "name": "SetRangeValue", "payload": { "rangeValue": 100 } } }, { "@type": "ActionsToDirective", "actions": [ "Alexa.Actions.Raise" ], "directive": { "name": "SetRangeValue", "payload": { "rangeValue": 0 } } } ], "stateMappings": [ { "@type": "StatesToValue", "states": [ "Alexa.States.Open" ], "value": 0 }, { "@type": "StatesToRange", "states": [ "Alexa.States.Closed" ], "range": { "minimumValue": 1, "maximumValue": 100 } } ] } }, { "type": "AlexaInterface", "interface": "Alexa.RangeController", "instance": "Blind.Angle", "version": "3", "properties": { "supported": [ { "name": "rangeValue" } ], "proactivelyReported": true, "retrievable": true, "nonControllable": false }, "capabilityResources": { "friendlyNames": [ { "@type": "text", "value": { "text": "Lamellenwinkel", "locale": "de-DE" } } ] }, "configuration": { "supportedRange": { "minimumValue": 1000, "maximumValue": 1090, "precision": 1 }, "unitOfMeasure": "Alexa.Unit.Angle.Degrees" } } ] } ], "scope": { "type": "BearerToken", "token": "access-token-from-Amazon" } } } }
"endpointId", "description", "friendlyName" are the only things I vary between the devices.
The following commands are alway working:
"Jalousie Küchentür öffnen" (kitchen door blind open)
"Jalousie Küchentür auf 50%" (kitchen door blind to 50%)
The following commands are only working for the previously added devices:
"Jalousie Küchentür stop" (kitchen door blind stop)
"Jalousie Küchentür sperren" (kitchen door blind block)
"Jalousie Küchentür Automatikbetrieb" (kitchen door blind automatic mode)
If I request all Smarthome Device configurations through the API
https://alexa.amazon.de/api/phoenix?includeRelationships=true
I can see that old and new devices only differ by some timestamps and IDs, nothing else.
I really don't understand why this stopped working.
