newuser-c0703988-2a74-4e04-b07f-a2e89d94a4fb avatar image
Alexa to trigger a webhook
Hey im trying to create an alexa skill that can Trigger a webhook with GET function.
I have searched on the internet but i haven't found a solution to that or how to create one.
i have a home automation system which works with an app called blynk which has buttons to control my appliances and the app has a feature so that the on/off can also be done by a GET webhook , so i want to integrate this feature with alexa skill but with out using IFTTT or ZAPIER because for the small tasks im doing they are very expensive, can anyone tell me a way to integrate webhooks with alexa skill manually?
alexa skills kitalexaalexa smart homeapiweb apps
Randy Thompson avatar image
Randy Thompson answered
Alexa cannot talk directly to your local devices. So, assuming the "webhook" Blynk provides is a public URL (a URL available outside of your local network), there are a lot of options available to you. If you are using JavaScript/Node.js to code your skill, for example, then you can use something like bent to issue a GET request.
