tonyparker avatar image
tonyparker asked
Error when starting sampleapp
Sorry if someone asked this issue previously. I have this problem when building sample app, followed by this guide:
https://developer.amazon.com/en-US/docs/alexa/avs-device-sdk/raspberry-pi-script.html
And here is the log:
https://paste.gg/p/anonymous/9cf0b07f7eb94fe3bd6be8d851bba53d
I'm using RPi 3B+, with lastest Raspbian, 1024mb swap. Thanks so much
alexa voice serviceaccount linking
KirkC@Amazon avatar image
KirkC@Amazon answered
The AVS Device SDK team has documented some of the most common issues that developers encounter here:
https://developer.amazon.com/en-US/docs/alexa/avs-device-sdk/troubleshooting.html
If that doesn’t address your question though, the AVS Device SDK team can also be reached via the “Issues” tab of the “avs-device-sdk” GitHub repository. There you’ll be able to use the search bar to look for past resolved issues. If no solution is found though, you may click the “New issue” button to ask your question:
https://github.com/alexa/avs-device-sdk/issues
