Hi All,
I am developing a product using the Alexa Echo device. When I give the "Alexa Dim 0%" command device turns OFF correctly. But when I give the "Alexa Turn ON" command it sends (254) 0xFE value instead of the last brightness value (means example before operating dim 0% my last dim value was 20%).
logs,
<info> app: Set level value: 255
<warning> app: Production config is not present or invalid
<info> app: Joined network successfully
<info> app: zcl_device_cb id 0
<info> app: on/off attribute setting to 0
<info> app: Set ON/OFF value: 0
<info> app: zcl_device_cb status: 0
<info> app: on/off attribute setting to 1
<info> app: Set ON/OFF value: 1
<info> app: zcl_device_cb id 7
<info> app: Level control setting to 26
<info> app: Set level value: 26
<info> app: Level control setting to 1
<info> app: Set level value: 1
<info> app: Level control setting to 254
<info> app: Set level value: 254
<info> app: Level control setting to 52
<info> app: Set level value: 52
So, what is the reason behind sending full (0xfe) value instead of previous brightness values?
Can anyone help me with this as it is urgent to solve?
Thanks in advance,
Regards
Rohit R
