I'm trying to pinpoint an issue with HD 8 plus devices while seeing if my application, both as a web app or as an android pwa apk, can run. Upon testing with the WAT, lowmemorykiller kills my application due to the performancetester taking up too much memory. Upon testing my apk, my app eventually dies as well thanks to the lowmemorykiller. Upon checking, performancetester is taking up about 1.5 gb of memory through WAT. Upon checking logs, my apk process is killed for only taking up 33 mb. Clearly this isn't an issue with my application so much as an issue with how HD 8 plus's handle memory allocation.
Logs belonging to my hd 8 plus where my application was killed by LMK:
03-03 18:53:07.815 355 355 I lowmemorykiller: Killing 'com.cisco.anyconnect.vpn.android.avf' (20843), uid 10172, adj 900
03-03 18:53:07.815 355 355 I lowmemorykiller: to free 39072kB because system is under medium memory pressure oom_adj 900
03-03 18:53:07.815 355 355 I lowmemorykiller: Killing 'air.com.myapplication' (10255), uid 10007, adj 900
03-03 18:53:07.815 355 355 I lowmemorykiller: to free 33608kB because system is under medium memory pressure oom_adj 900
03-03 18:53:07.816 355 355 I lowmemorykiller: Killing 'com.android.documentsui' (16153), uid 10011, adj 900
03-03 18:53:07.816 355 355 I lowmemorykiller: to free 38416kB because system is under medium memory pressure oom_adj 900
03-03 18:53:07.816 355 355 I lowmemorykiller: Killing because cache 163216kB is below limit 163840kB for oom_adj 900
03-03 18:53:07.816 355 355 I lowmemorykiller: Free memory is 4080kB above reserved
03-03 18:53:07.816 355 355 I lowmemorykiller: Reclaimed enough memory (pages to free=50180, pages freed=54509)
03-03 18:53:07.817 355 355 I lowmemorykiller: Killing 'com.android.settings' (19043), uid 1000, adj 900
03-03 18:53:07.817 355 355 I lowmemorykiller: to free 53976kB because system is under low memory pressure oom_adj 900
03-03 18:53:07.817 355 355 I lowmemorykiller: Killing 'com.amazon.kindle.unifiedSearch' (24027), uid 10016, adj 900
03-03 18:53:07.817 355 355 I lowmemorykiller: to free 56852kB because system is under low memory pressure oom_adj 900
03-03 18:53:07.817 355 355 I lowmemorykiller: Killing because cache 162916kB is below limit 163840kB for oom_adj 900
03-03 18:53:07.817 355 355 I lowmemorykiller: Free memory is 4584kB above reserved
Note that many processes are killed due to low memory aside from air.com.lexialearning.core5. Of these processes, air.com.lexialearning.core5 is taking up a small amount of memory in comparison at only 33608kB (or about 33 to 34 mb of memory).
Note that this is only happening on the HD 8 plus specifically?
