newuser-98a88166-9c07-45bd-a735-2ed52e7371a4 avatar image
Playback nearly finsihed function updates the list of mp3 links when the second request is initiated and that affects the playlist of the other user
I have a variable in the playback nearly finished function in the lambda which gets data from the external API. This variable is then played from its first link to last but when a new user launches the request, this variable gets updated with that value and even the first user then gets that different playlist of the second user.
class PlaybackNearlyFinishedEventHandler(AbstractRequestHandler):
"""AudioPlayer.PlaybackNearlyFinished Directive received.
Replacing queue with the URL again. This should not happen on live streams.
def can_handle(self, handler_input):
# type: (HandlerInput) -> bool
return is_request_type("AudioPlayer.PlaybackNearlyFinished")(handler_input)
def handle(self, handler_input):
# type: (HandlerInput) -> Response
logger.info("In PlaybackNearlyFinishedHandler")
#global total_links
try_var=ob1.get_x()
persistent_attr = handler_input.attributes_manager.persistent_attributes
playback_info = persistent_attr.get("playback_info")
playback_setting = persistent_attr.get("playback_setting")
if playback_info.get("next_stream_enqueued"):
return handler_input.response_builder.response
test_var=handler_input.attributes_manager.persistent_attributes["total_links"]
user_id = handler_input.request_envelope.context.system.user.user_id
user_var=""
user_var+=user_id
response = table_user.get_item(
Key={
'UserID': user_id,
'links': 'test'
item = response['Item']
print(item)
# This value gets updated when a second user initiates the alexa request.
a_dict={}
a_dict[user_id]=item['info']
print(a_dict[user_id])
test_link=item['info']
total_links=test_link
playback_info["next_stream_enqueued"] = True
count_local= int(playback_info.get("token"))
count_local+=1
expected_previous_token = int(playback_info.get("token"))
playback_info["token"] = int(playback_info.get("token"))
playback_info["token"]+=1
enqueue_token = playback_info.get("token")
play_behavior = PlayBehavior.ENQUEUE
url = a_dict[user_id][count_local]
offset_in_ms = 0
handler_input.response_builder.add_directive(
PlayDirective(
play_behavior=play_behavior,
audio_item=AudioItem(
stream=Stream(
token=enqueue_token,
url=url,
offset_in_milliseconds=offset_in_ms,
expected_previous_token=expected_previous_token),
metadata=None)))
lambdaaudioplayerplaybackcontroller
Andy Whitworth avatar image
Andy Whitworth answered
I'm not a python developer but this sounds like a simple variable scope problem. You need to ensure that you're not updating global variables as they will be shared across multiple user invocations of your lambda. Store playlists etc in the persistent storage associated with each individual user request.
