i'm developing a prototype for an IoT lamp that should be released commercially in the upcoming future. I'm using the board ESP8266 NodeMCU v3.
I'd like to integrate Alexa basic controls for this lamp. The device should be able to get turn on and off from any location...using the alexa app or an Echo device ( if the user is at home ).
We are not a company, and we have no revenue
What's the best way to accomplish this? I found myself good with ACK, i even revisited the sample app to fit my basic needs for the lamp interaction.
But there is one little problem, i don't understand if it is a compatibility issue, or just the environment...when using the latest Module Utility for Espressif chipsets, i can list the available port, and it is not inUse... but i can't use deviceinfo on that port, i can't provision the device and i can't even flash the ACK_Firmware_0015 into the board. The error is still the same
Error 1003 : Error : Module did not respond correctly. Check port and module
I'm running Ubuntu 20.10 and Java 15.0.2
I even tried to do a factory reset of the board using esptool erase_flash but still i got the same error...
Could you please help me understand better this problem? I'd also really appreciate any suggestions regarding the possible implementations for this lamp... we also have a companion app for it running on Android. So... i really don't know what decisions to take at this point...
Thanks in advance!
EDIT:
As suggested by Karunish@Amazon i tried to downgrade my Java version to 8 ( later on i tried even 11) but the error still persists...
