ask deploy
will usually deploy the entire package. Is there a way just to update the skill package, in particular the skill.json using CLI?
ask deploy
Hello @tg and thank you for your message.
If you execute ask deploy -h
here is what the output will tell you:
ask deploy -h Usage: ask deploy [options] deploy the skill project Options: --ignore-hash [OPTIONAL] Forces the ASK CLI deploy skill package even if the hash of current skill package folder does not change. -t, --target <target> [OPTIONAL] Specify which skill project resource to deploy. [ENUM]: skill-metadata,skill-infrastructure -p, --profile <profile> [OPTIONAL] Provides the ASK CLI profile to use. When you dont include this option, ASK CLI uses the default profile. --debug [OPTIONAL] Enables the ASK CLI to show debug messages in the output of the command. -h, --help output usage information
In other words, you can use ask deploy -t skill-metadata
to deploy only the skill package.
Regards,
Barry
1 Person is following this question.
