NiceToMytyuk avatar image
NiceToMytyuk asked
How to delete persistent attributes?
I have an Alexa-Hosted skill which register attributes in persistent attributes, but as i'm testing the skill for now i need to delete the saved attributes as it's save a unique code for the user, how can i delete or clear the persistent attributes?
for set attributes i use
attributesManager.setPersistentAttributes(sessionAttributes);
attributes
Kinisoftware avatar image
Kinisoftware answered
Hi @NiceToMytyuk ! :)
It depends on the persistence connector you are using. For skills it should be S3 or DynamoDB. You should be able to access to your persistent attributes in the persistence layer (bucket or table) and remove them from it.
I guess you already know this but, by code, you have a method in the attributesManager for it
attributesManager.deletePersistentAttributes();
Hope I was able to help you :)
