shanthi avatar image
shanthi asked
ALEXA send response asynchronously through EVENTS gateway
I have followed all steps mentioned here https://developer.amazon.com/en-US/docs/alexa/smarthome/send-events-to-the-alexa-event-gateway.html till retrieving the bearer token. But I would like to know exactly how do we send a asynchronous response to Alexa? If you see the example here
POST /v3/events HTTP/1.1
Host: api.amazonalexa.com
Authorization: Bearer access-token-from-Amazon
Content-Type: application/json
  "context": {
    "properties": [
  "event": {
    "header": {
      "messageId": "abc-123-def-456",
      "correlationToken": "abcdef-123456",
      "namespace": "Alexa",
      "name": "Response",
      "payloadVersion": "3"
    "endpoint": {
      "scope": {
        "type": "BearerToken",
        "token": "access-token-from-Amazon"
       "endpointId" :  "endpoint-id"
    "payload": {
There is a mention of endpoint-id? What is the endpoint-id for the alexa device itself? How can I send a response to alexa? I just want to send a "hello world" response which alexa will voice it out when I send it through an events gateway? Can anyone show me a sample? Thanks
The flow I will be using is
Alexa calls aws lambda
Lambda sends a deferred response synchronously
Then after some time I would like to send a response message to alexa asynchronously
But all the example codes I have seen mention an endpointid. I am not sure what it is? I just want to send a simple response which alexa needs to voice it out. That's all Is it possible at all? THANKS
alexa skills kitalexa voice servicealexaalexa dev daysalexa skills challenge
Can anyone help me? Can you please post an example of a simple async Response to ALexa through the event gateway, all alexa has to do is voice out the response that's it.Many Thanks Please note I have reached till the part where Bearer token is received successfully and then access and refresh tokens too all are good.
