Damian avatar image
Damian asked ·
Apple Silicon/M1 "building for iOS Simulator, but linking in object file built for iOS, for architecture arm64"
Trying to build and run an iOS app in the Simulator on an Apple Silicon (M1) based Mac using LWA gives the error
ld: in /Users/damian/Projects/myapp/Frameworks/LoginWithAmazon.framework/LoginWithAmazon(AMZNAuthorizationManager.o), building for iOS Simulator, but linking in object file built for iOS, for architecture arm64
The exact same code built and ran on Intel based macs.
I think that the LWA SDK will need to be built/shipped with support for Apple Silicon - any thoughts on this? Happy to beta test.
Damian
ios
Chandan avatar image
Chandan answered ·
double click of architecture and select other and remove all lines and add two things arm7s and arm7
Example Image Click Here
Damian avatar image
Damian answered ·
When I build for the simulator after removing everything and adding `arm7s` and `arm7` then I get `None of the architectures in ARCHS (arm7, arm7s) are valid. Consider setting ARCHS to $(ARCHS_STANDARD) or updating it to include at least one value from VALID_ARCHS (arm64, arm64e, i386, x86_64).`
If I leave `Standard Architectures` and add `arm7s` and `arm7` I get the same error as before.
