I'm planning to build a speaker that supports Alexa Cast, so it can be used it with the Amazon Music mobile app. It should appear as an Alexa Cast-able device in the app.
Is this supported through the AVS Device SDK? I.e.:
- Does the AVS Device SDK support Alexa Cast?
- Does the device need to be certified to use Amazon Music, or is that irrelevant because playing music from Amazon Music is exclusively done through Alexa Cast in my use case?
Gunnar
