newuser-a132b23c-8238-4e14-8f5c-be291e590e48 avatar image
Bug with Android Login with Amazon SDK, doesn't return to app
Firstly: how do i even report a bug with the sdk?! Is this the only way?
Secondly:
I'm using the Login with Amazon sdk, and it looks like if I try to initiate login and I've already linked my account and the webpage I'm directed to asks me if I'd like to "allow" access, once I press "allow" it doesn't return me to my app.
I see the following in my logs, so I know we've received the response:
2020-12-10 13:53:55.918 22477-22477/*****.debug D/com.amazon.identity.auth.device.workflow.WorkflowActivity: onCreate
2020-12-10 13:53:55.920 22477-22477/*****.debug D/com.amazon.identity.auth.device.workflow.WorkflowActivity: Receiving response for interactive request
2020-12-10 13:53:55.922 22477-22477/*****.debug D/com.amazon.identity.auth.device.workflow.WorkflowActivity: Receiving response for request 54d738f3-a66e-4d31-a4b2-e59e38cce615
2020-12-10 13:53:55.922 22477-22477/*****.debug D/com.amazon.identity.auth.device.ResponseManager: Recording pending response for request ID 54d738f3-a66e-4d31-a4b2-e59e38cce615
2020-12-10 13:53:55.922 22477-22477/*****.debug D/com.amazon.identity.auth.device.workflow.WorkflowActivity: finish
But the original Activity where the call was made isn't returning.
Also, does it matter if I use an activity or the application context when creating the "RequestContext"?
login with amazonandroid
Levon@Amazon avatar image
Levon@Amazon answered
Hi there,
Can you please provide full device logs when this issue occurs? Could you please also share some screenshots or a short video of the issue for better understanding.
Please log in to your Developer Portal account and use the "Contact Us" form to send us those files. Thanks!
