newuser-c5f4ef60-81bc-4531-9f4a-8ed4043378c8 avatar image
Add temperature sensor to routine
I have a temperature sensor, but cannot add it to routine as a trigger.
I'm not sure what the reason.
Is this because my discover response?
Here is the response :
    "event":{
        "header":{
            "messageId":"234572-f513-4821-bc75-e70c759bbe49",
            "name":"Discover.Response",
            "namespace":"Alexa.Discovery",
            "payloadVersion":"3"
        "payload":{
            "endpoints":[
                    "capabilities":[
                            "interface":"Alexa",
                            "type":"AlexaInterface",
                            "version":"3"
                            "interface":"Alexa.EndpointHealth",
                            "properties":{
                                "proactivelyReported":true,
                                "retrievable":true,
                                "supported":[
                                        "name":"connectivity"
                            "version":"3"
                            "interface":"Alexa.TemperatureSensor",
                            "properties":{
                                "retrievable":true,
                                "supported":[
                                        "name":"temperature"
                            "version":"3"
                    "cookie":{
                    "description":"xxxx",
                    "displayCategories":[
                        "TEMPERATURE_SENSOR"
                    "endpointId":"0000000000000000000024dfa734915e_404",
                    "friendlyName":"tem",
                    "manufacturerName":"BroadLink",
                    "additionalAttributes":{
                        "manufacturer":"xxx",
                        "model":"xxx",
                        "serialNumber":"xxx",
                        "firmwareVersion":"xxx",
                        "softwareVersion":"xxx",
                        "customIdentifier":"0000000000000000000024dfa734915e_404"
skillsmart homeroutines
