when I try to run the FFS demo on my Mac the logs show get the following error:
* Trying 10.201.126.241:8888... * TCP_NODELAY set * Connected to dp-sps-na.amazon.com (10.201.126.241) port 8888 (#0) * ALPN, offering http/1.1 * successfully set certificate verify locations: * CAfile: none CApath: ./data/dss_certificates/ * SSL certificate problem: unable to get local issuer certificate * Closing connection 0 2020-10-27T19:27:02.508Z [ERROR] ffsHttpExecutePreallocated:200: Curl operation curl_easy_perform(session) returned 60 (SSL peer certificate or SSH remote key was not OK) 2020-10-27T19:27:02.508Z [ERROR] ffsHttpExecutePreallocated:200: FAILED with ERROR 2020-10-27T19:27:02.508Z [ERROR] ffsHttpExecute:90: result returned ERROR 2020-10-27T19:27:02.508Z [DEBUG] ffsDssClientHttpExecute:534: DSS client received HTTP status code: 0 2020-10-27T19:27:02.508Z [ERROR] ffsDssClientHttpExecute:537: result returned ERROR 2020-10-27T19:27:02.508Z [ERROR] ffsDssClientExecute:130: ffsDssClientHttpExecute(dssClientContext, &httpRequest, &dssResponse) returned ERROR 2020-10-27T19:27:02.508Z [ERROR] ffsDssStartProvisioningSession:77: ffsDssClientExecute(dssClientContext, &FFS_DSS_OPERATION_DATA_START_PROVISIONING_SESSION, &bodyStream, &operationData) returned ERROR 2020-10-27T19:27:02.509Z [ERROR] ffsEncodeJsonStringField:703: FAILED with ERROR 2020-10-27T19:27:02.509Z [ERROR] ffsDssStartSerializingReportRequest:45: ffsEncodeJsonStringField(JSON_KEY_SESSION_ID, reportRequest->sessionId, outputStream) returned ERROR 2020-10-27T19:27:02.509Z [ERROR] ffsConstructReportHttpRequestBody:134: ffsDssStartSerializingReportRequest(&reportRequest, bodyStream) returned ERROR 2020-10-27T19:27:02.509Z [ERROR] ffsDssReport:85: ffsConstructReportHttpRequestBody(dssClientContext, provisioneeState, stateTransitionResult, registrationState, getConnectionAttemptsCallback, wifiConnectionAttempt, &bodyStream) returned ERROR 2020-10-27T19:27:02.509Z [ERROR] ffsWifiProvisioneeTaskExecuteStateStartProvisioning:264: ffsDssReport(taskContext->dssClientContext, FFS_DSS_WIFI_PROVISIONEE_STATE_START_PROVISIONING, (result == FFS_SUCCESS ? FFS_DSS_REPORT_RESULT_SUCCESS : FFS_DSS_REPORT_RESULT_FAILURE), dssRegistrationState, &taskContext->cloudCanProceed, &nextDssProvisioneeState, ffsWifiGetDssConnectionAttemptsCallback, &taskContext->wifiConnectionAttempt) returned ERROR 2020-10-27T19:27:02.509Z [ERROR] ffsWifiProvisioneeTaskExecuteState:172: ffsWifiProvisioneeTaskExecuteStateStartProvisioning(taskContext) returned ERROR 2020-10-27T19:27:02.509Z [ERROR] ffsWifiProvisioneeTask:146: ffsWifiProvisioneeTaskExecuteState(&taskContext, state) returned ERROR 2020-10-27T19:27:02.509Z [ERROR] main:50: ffsWifiProvisioneeTask(&userContext) returned ERROR
I am using test certificates which I requested a while back. Are they invalid by now? Do I need any other certificates?
