I am trying to test Amazon IAP with App Tester and the onPurchaseResponse is not being sent after calling the purchase method.
Some events are received, for instance, the onPurchaseUpdatesResponse.
I have just downloaded the App Tester, and I am using the in-app-purchasing-2.0.76.jar
I noted the following exception after the purchase method is called:
2020-10-27 16:43:44.580 958-5524/? E/Parcel: Class not found when unmarshalling: com.amazon.sdktestclient.iap.command.IapCommandResponse java.lang.ClassNotFoundException: com.amazon.sdktestclient.iap.command.IapCommandResponse at java.lang.Class.classForName(Native Method) at java.lang.Class.forName(Class.java:454) at android.os.Parcel.readParcelableCreator(Parcel.java:3031) at android.os.Parcel.readParcelable(Parcel.java:2981) at android.os.Parcel.readValue(Parcel.java:2883) at android.os.Parcel.readArrayMapInternal(Parcel.java:3261) at android.os.BaseBundle.initializeFromParcelLocked(BaseBundle.java:292) at android.os.BaseBundle.unparcel(BaseBundle.java:236) at android.os.BaseBundle.getString(BaseBundle.java:1160) at android.content.Intent.getStringExtra(Intent.java:8548) at com.android.server.wm.ActivityStarter.startActivity(ActivityStarter.java:765) at com.android.server.wm.ActivityStarter.startActivity(ActivityStarter.java:676) at com.android.server.wm.ActivityStarter.startActivityMayWait(ActivityStarter.java:1783) at com.android.server.wm.ActivityStarter.execute(ActivityStarter.java:607) at com.android.server.wm.ActivityTaskManagerService.startActivityAsUser(ActivityTaskManagerService.java:1615) at com.android.server.wm.ActivityTaskManagerService.startActivityAsUser(ActivityTaskManagerService.java:1512) at com.android.server.wm.ActivityTaskManagerService.startActivity(ActivityTaskManagerService.java:1466) at android.app.IActivityTaskManager$Stub.onTransact(IActivityTaskManager.java:1655) at android.os.Binder.execTransactInternal(Binder.java:1056) at android.os.Binder.execTransact(Binder.java:1029) Caused by: java.lang.ClassNotFoundException: com.amazon.sdktestclient.iap.command.IapCommandResponse at java.lang.Class.classForName(Native Method) at java.lang.Class.forName(Class.java:454) at android.os.Parcel.readParcelableCreator(Parcel.java:3031) at android.os.Parcel.readParcelable(Parcel.java:2981) at android.os.Parcel.readValue(Parcel.java:2883) at android.os.Parcel.readArrayMapInternal(Parcel.java:3261) at android.os.BaseBundle.initializeFromParcelLocked(BaseBundle.java:292) at android.os.BaseBundle.unparcel(BaseBundle.java:236) at android.os.BaseBundle.getString(BaseBundle.java:1160) at android.content.Intent.getStringExtra(Intent.java:8548) at com.android.server.wm.ActivityStarter.startActivity(ActivityStarter.java:765) at com.android.server.wm.ActivityStarter.startActivity(ActivityStarter.java:676) at com.android.server.wm.ActivityStarter.startActivityMayWait(ActivityStarter.java:1783) at com.android.server.wm.ActivityStarter.execute(ActivityStarter.java:607) at com.android.server.wm.ActivityTaskManagerService.startActivityAsUser(ActivityTaskManagerService.java:1615) at com.android.server.wm.ActivityTaskManagerService.startActivityAsUser(ActivityTaskManagerService.java:1512) at com.android.server.wm.ActivityTaskManagerService.startActivity(ActivityTaskManagerService.java:1466) at android.app.IActivityTaskManager$Stub.onTransact(IActivityTaskManager.java:1655) at android.os.Binder.execTransactInternal(Binder.java:1056) at android.os.Binder.execTransact(Binder.java:1029)
