Hello, as title says I had problems with job definition for interaction model creation.
I created my catalog with command : ask smapi create-interaction-model-catalog --catalog-name myCatalogName --profile myProfile
Than a catalog version : ask smapi create-interaction-model-catalog-version --catalog-id myCatalogID --source-type URL --source-url "myJsonUrl" --description "initial" --profile myProfile
Now my catalog is successfully created and i can also check it with the command : ask smapi list-interaction-model-catalogs --profile myProfile
And i become my catalog id and name as it should be.
When I run the command without the profile : ask smapi list-interaction-model-catalogs
Than I don't become the catalog id and name as it should be, so the catalog is created and it is in the right profile.
Than i try to create a job using the following Json file :
"vendorId": "myVendorID",
"jobDefinition": {
"type": "ReferenceVersionUpdate",
"resource": {
"type": "InteractionModel",
"locales": ["de-DE"],
"id": "myAlexaSkillID"
"references": [{
"type": "Catalog",
"id": "myCatalogID"
"trigger": {
"type": "ReferencedResourceJobsComplete"
"publishToLive": false,
"status": "ENABLED"
with the command : ask smapi create-job-definition-for-interaction-model --job-definition
"file:pathToMyJsonFile" --profile myProfile
Sadly after that command i become always a negative response :
[Error]: {
"name": "ServiceError",
"statusCode": 404,
"headers": [ ........... ],
"response": {
"message": "Dependent entity=myCatalogID not found"
myCatalogID is correct and it exist on myProfile, same with myVendorID I use the correct one.
Any clue about this error?
