newuser-1c7559e0-ea08-4158-8fd0-49ced031509d avatar image
Is there any Documentation for UPNP support of echo devices?
UPNP - Virtual Binary Light (ON/OFF Light)
We would like to implement an virtual upnp device which can be found and controlled by an echo device (without any Alexa Skill). We have already implemented the general upnp handling and some simple virtuell devices like an upnp light switch (which will be detected by any echo device). But now we would like to implement a binary light as described here.
Now, when we use this xml template (filled up with real data) and start the device discovery of an echo dot, the following happens:
  • Echo Dot requests our device description xml file for the binary light (setup.xml), which it receives.
  • After that, the discovery process ends, but the Alexa app says that no new devices have been found.
Is there a way to get an working example of an upnp binary light device description xml file? Or is there anybody we could contact to get further information about the upnp support of echo devices?
alexaecho
Arm avatar image
Arm answered
Howdy! Perhaps not the documentation you were looking for but I've done some black box reverse engineering of the communication between the echo and a first gen phillips hue hub. The first gen hue hubs do not require cloud connectivity and uses UPNP for service discovery.
an example of it is here
https://github.com/armzilla/amazon-echo-ha-bridge/blob/master/src/main/java/com/armzilla/ha/upnp/UpnpSettingsResource.java
Bonfra avatar image
Bonfra answered
Hi, did you find anything useful? I'm essentially facing the same issue now
