newuser-a1c537de-786d-4683-8dbe-bf63af254646 avatar image
newuser-a1c537de-786d-4683-8dbe-bf63af254646 asked ·
Charging port moisture error
get Fire 10 error: charging disabled due to moisture detection. But never wet, no moisture (Amazon Forum shows this as common, only solution is warranty return.) However, I'd rather disable unneeded moisture sensor, I will not get it wet. Any of the Settings--Apps--Show System I can Force Stop? (that's an android phone solution, any for Kindle?) Or de we just have to return it when it won't charge due to error?
fire tablet
Try changing the cable you are using. I had this problem on vacation. I was using a cable I dug out of a drawer. I got the water error the first time I used it. I tried rebooting the tablet. Nothing worked. In desperation I retrieved the short cable I have used to connect my phone in my car. Tried that and it worked perfectly. Some of these cables can't be trusted.
newuser-a1c537de-786d-4683-8dbe-bf63af254646 answered ·
thanks, forum and google didn't have an answer so I thought developers might, but I found one anyway:
Reset and auto updates did not fix it. But when I tapped Check for Updates in settings, device, it found 14 system updates, I installed them, still got error. But I held down power for a minute for hard reset and it worked. Really weird, I'll tell forum.
Levon@Amazon avatar image
Levon@Amazon answered ·
Hi there,
Thanks for posting. Please note that this is a forum for Amazon Appstore developers. For assistance with the Amazon devices as an end user, please either:
- post in Amazon Digital and Device Forum: https://www.amazonforum.com/
- contact Amazon Customer Service for support: http://www.amazon.com/customerservice
Thanks!
