newuser-52504b4f-777b-473e-a1cd-a04486128616 avatar image
Not able to discover my devices. Please Help.
Till yesterday I was able to discover devices but not nothing is being shown now. Currently I have created some virtual devices and they were being shown and discovered but now I can't discover them.
I'm trying to create a Smart Home Skill.
This is the response that I get from running DiscoverDirective Test in AWS Lambda.
  "event": {
    "header": {
      "namespace": "Alexa.Discovery",
      "name": "Discover.Response",
      "payloadVersion": "3",
      "messageId": "20d16f3a-c6b4-476a-a522-3a6d4ee25693"
    "payload": {
      "endpoints": [
          "endpointId": "endpoint-001",
          "manufacturerName": "Sample Manufacturer",
          "friendlyName": "Switch",
          "description": "001 Switch that can only be turned on/off",
          "displayCategories": [
            "SWITCH"
          "cookie": {
            "detail1": "For simplicity, this is the only appliance",
            "detail2": "that has some values in the additionalApplianceDetails"
          "capabilities": [
              "type": "AlexaInterface",
              "interface": "Alexa.PowerController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "powerState"
                "proactivelyReported": true,
                "retrievable": true
              "interface": "Alexa.EndpointHealth",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "connectivity"
                "retrievable": true
              "interface": "Alexa",
              "version": "3"
          "endpointId": "endpoint-002",
          "friendlyName": "Light",
          "description": "002 Light that is dimmable and can change color and color temperature",
            "LIGHT"
          "cookie": {},
          "capabilities": [
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "interface": "Alexa.ColorController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "color"
                "retrievable": true
              "interface": "Alexa.ColorTemperatureController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "colorTemperatureInKelvin"
                "retrievable": true
              "interface": "Alexa.BrightnessController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "brightness"
                "retrievable": true
              "interface": "Alexa.PowerLevelController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "powerLevel"
                "retrievable": true
              "interface": "Alexa.PercentageController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "percentage"
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
          "endpointId": "endpoint-003",
          "friendlyName": "White Light",
          "description": "003 Light that is dimmable and can change color temperature only",
            "LIGHT"
          "cookie": {},
          "capabilities": [
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
          "endpointId": "endpoint-004",
          "friendlyName": "Thermostat",
          "description": "004 Thermostat that can change and query temperatures",
            "THERMOSTAT"
          "cookie": {},
          "capabilities": [
              "interface": "Alexa.ThermostatController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "targetSetpoint"
                    "name": "thermostatMode"
                "retrievable": true
              "interface": "Alexa.TemperatureSensor",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "temperature"
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
          "endpointId": "endpoint-004-1",
          "friendlyName": "Living Room Thermostat",
          "description": "004-1 Thermostat that can change and query temperatures, supports dual setpoints",
            "OTHER"
          "cookie": {},
          "capabilities": [
              "version": "3",
              "properties": {
                "supported": [
                    "name": "upperSetpoint"
                    "name": "lowerSetpoint"
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
          "endpointId": "endpoint-005",
          "friendlyName": "Lock",
          "description": "005 Lock that can be locked and can query lock state",
            "SMARTLOCK"
          "cookie": {},
          "capabilities": [
              "interface": "Alexa.LockController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "lockState"
                "retrievable": true
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
          "endpointId": "endpoint-006",
          "friendlyName": "Good Night Scene",
          "description": "006 Scene that can only be turned on",
            "SCENE_TRIGGER"
          "cookie": {},
          "capabilities": [
              "interface": "Alexa.SceneController",
              "version": "3",
              "supportsDeactivation": false,
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
          "endpointId": "endpoint-007",
          "friendlyName": "Watch TV",
          "description": "007 Activity that runs sequentially that can be turned on and off",
            "ACTIVITY_TRIGGER"
          "cookie": {},
          "capabilities": [
              "version": "3",
              "supportsDeactivation": true,
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
          "endpointId": "endpoint-008",
          "friendlyName": "Baby Camera",
          "description": "008 Camera that streams from an RSTP source",
            "CAMERA"
          "cookie": {},
          "capabilities": [
              "interface": "Alexa.CameraStreamController",
              "version": "3",
              "cameraStreamConfigurations": [
                  "protocols": [
                    "RTSP"
                  "resolutions": [
                      "width": 1280,
                      "height": 720
                  "authorizationTypes": [
                    "NONE"
                  "videoCodecs": [
                    "H264"
                  "audioCodecs": [
                    "AAC"
              "version": "3",
              "properties": {
                "supported": [
                "retrievable": true
              "version": "3"
I'm not able discover the devices from the Alexa App and also not in Developer console.
AWS Lambda: arn:aws:lambda:us-east-1:257285270416:function:LightsDemoFunction
Smart Home Skill: amzn1.ask.skill.8de7b4ea-b170-480c-b59e-b4a96e7bfbe4
I have cross checked and Smart Home Trigger and Endpoints are correctly added. If anyone have any idea then it will be great as I'm already stuck on this for a day now.
alexa skills kitalexaalexa smart homesmart homealexa skills
Gaetano@Amazon avatar image
Gaetano@Amazon answered
Hello and thanks for posting.
I can see that you have opened a contact-us case as well, in which we are waiting for an answer about some info related to your account.
Can you please look into it?
Thanks,
Gaetano
