newuser-ece92cf0-b91d-4353-8319-16105d46c99a avatar image
Change textcolor of Alexa Header/Footer
I'm using the AlexaHeader and AlexaFooter elements of APL and changed the default text color for my skill. Since by default the textstyle does not apply to these header / footer elements, I was wondering how to change the font color there.
Thank you in advance!
Kind regards,
Peter
alexa skills kitalexaapldesign
Alexander Martin avatar image
Alexander Martin answered
you can either use the "theme" attribute to change the text color. Possible values are "light" and "dark", or you can overwrite the resources "colorTextReversed", "colorTextSecondary" and "colorTextSecondaryReversed" like I did in my example with your own color code. The Reversed properties are used for the theme "dark".
    "type": "APL",
    "version": "1.4",
    "settings": {},
    "theme": "dark",
    "import": [{
        "name" :"alexa-layouts",
        "version": "1.2.0"
    "resources": [{
        "colors": {
            "colorTextReversed": "#ff0000",
            "colorTextSecondary": "#ffd700",
            "colorTextSecondaryReversed": "#ff0000"
    "styles": {},
    "onMount": [],
    "graphics": {},
    "commands": {},
    "layouts": {},
    "mainTemplate": {
        "parameters": [
            "payload"
        "items": [{
            "type": "AlexaHeader",
            "headerTitle": "Primary Text",
            "headerSubtitle": "Subtitle",
            "theme": "dark"
Regards,
Alex
newuser-ece92cf0-b91d-4353-8319-16105d46c99a answered
Thank you very much @Alexander Martin! Worked as expected.
