newuser-58d44efb-7468-47e4-a404-99a6ad2865b0 avatar image
Problem trying to enable CanFulfillIntentRequest
I'm following that guide but it is not working for me.
I see the CanFulfillIntentRequest is from 2018. Is it still in BETA or was removed from Alexa?
https://developer.amazon.com/en-US/docs/alexa/custom-skills/implement-canfulfillintentrequest-for-name-free-interaction.html#canfulfill-dev-console
I had two problems:
1) ask api does not exists anymore at ask 2.x. So I installed ask 1.7.23 to run the commands.
2) After change skill.json with interface CAN_FULFILL_INTENT_REQUEST I updated my skill and check it with ask api get-skill. It is updated. But the Build / Custom / Interfaces pages is not showing the item CanFulfillIntentRequest to enable it.
Do you know what is happening?
Hello and thank you for your message.
At the time of this writing, the CanFulfillIntentRequest is still in Beta.
Regarding the problems you listed:
  1. Most of the ask api commands from V1 have been replaced by ask smapi. This page contains a list of all the ask smapi subcommands. If the one you are looking for is not there, please let me know.
  2. I have manually changed my skill's skill.json to add the CAN_FULFILL_INTENT_REQUEST interface and deployed. Checking the developer console, I can see that the interface is toggled. Make sure that the manifest is correctly formatted, with all the objects nested in the correct place. This page contains a sample manifest that you can use to compare yours.
Regards,
Barry
