newuser-eac05702-1f93-4198-9d70-3d836767d200 avatar image
Reminders API - Out of session help
Hi:
I need help and perhaps clarification.
Based on a very simple skill (think hello world) I need to be able to push reminders using a tool like postman (assuming is possible).
I've been following tutorials and so far I have been able to obtain a token using https://api.amazon.com/auth/o2/token
"access_token": "Atc|tokendatahere",
"scope": "alexa:skill_messaging",
"token_type": "bearer",
"expires_in": 3600
With the token I try to use https://api.amazonalexa.com/v1/alerts/reminders to post a new reminder using a body like:
"requestTime" : "2020-06-22T16:34:00.672",
"trigger": {
"type" : "SCHEDULED_ABSOLUTE",
"scheduledTime" : "2020-06-22T17:00:00.000",
"timeZoneId" : "America/Chicago",
"recurrence" : {
"startDateTime": "2020-06-22T7:00:00.000",
"endDateTime" : "2020-06-23T10:00:00.000",
"recurrenceRules" : [
"FREQ=DAILY;BYHOUR=6;BYMINUTE=10;BYSECOND=0;INTERVAL=1;",
"FREQ=DAILY;BYHOUR=17;BYMINUTE=15;BYSECOND=0;INTERVAL=1;",
"FREQ=DAILY;BYHOUR=22;BYMINUTE=45;BYSECOND=0;INTERVAL=1;"
"alertInfo": {
"spokenInfo": {
"content": [{
"locale": "en-US",
"text": "walk the cow",
"ssml": "<speak> walk the cow</speak>"
"pushNotification" : {
"status" : "ENABLED"
However I keep getting an error 400 with the following response.
"code": "MISSING_CUSTOMER_ID",
"message": "customerId must be provided"
What am I missing?
Skill ID is amzn1.ask.skill.9a9cce81-838f-400e-a15a-a3db49dcac2b
Gracias,
Edgar
reminders
newuser-b12b824a-8dab-4a35-8df0-d8930acdc51a avatar image
newuser-b12b824a-8dab-4a35-8df0-d8930acdc51a answered
The same issue.
GranGran avatar image
GranGran answered
You are getting that due to using the wrong type of access_token. The documentation is really not that helpful for figuring this out, and I haven't quite mastered it, but I can say that you need an in-session token to create reminders. It is quite a long token at ~2600 characters.
I noticed that at least this endpoint doesn't give particularly consistent responses for errors. I accidentally copied and pasted some other text at the end of my key and go this same "MISSING_CUSTOMER_ID" error instead of a 401 unauthorized error I would have expected.
