niklasMay avatar image
niklasMay asked ·
Develop interaction model on local dev environment and push/pull to/from Alexa Developer Console
I am working with the ask-cli and have the code of my hosted skill (node.js) on my locale machine.
My goal is to be able to make changes on the interaction model on the amazon developer console (build tab) and then pull the changes on to my local machine. I also want to do the same thing the other way around.
Unfortunately i can only make this work for the lambda code, but not for the code in the package folder.
Is there any way to make this work?
ask clinode_jshosted skill
Rokas avatar image
Rokas answered ·
ask cli recently was bumped to v2 and now supports plethora of smapi commands. In your case you could probably use: get-interaction-modeland set-interaction-modelto manipulate skill interaction model.
